frustrated and not sure whats going on.
Old Jul 26, 2008 | 02:00 PM
BigBADGSX's Avatar
Been having problems with my 03 lately, anything above 21psi or so Im getting serious flutter/surge. Sometimes it will even happen at lower boost and gradually go away. At first i thought it might have been a boost control issue so I switched from my forge to a spare buschur inline mbc and still the same problems. switched from a spare ix bov i had to my forge and same issues. Im kinda lost, im thinking it might be something to do with my wg/actuator or maybe my turbo is bad.... P.S. this is still the stock turbo.
I have a video of an evo that seems to be having the SAME exact problem as me but im not sure if I can post it here(street racing). Dont wanna get in any trouble lol.
Some mods just to give you guys an idea what i have done:
forge mbc
forge bov(2 shims)
buschur delux fmic with lower pipe
buschur intake
255
full 3in tbe
dynoflash custom tune @ 21psi
any advice would be appreciated...
Old Jul 26, 2008 | 03:32 PM
vaflyboi757's Avatar
it's either plugs or boost cut, i had the same problem a year ago
Old Jul 26, 2008 | 03:59 PM
BigBADGSX's Avatar
watch this.... this is what my evo is doing... (not my car but the same issue)
http://videos.streetfire.net/video/0...-vs_169102.htm
Old Jul 26, 2008 | 04:27 PM
kim.ry's Avatar
forge mbc
forge bov(2 shims)
buschur intake
255
full 3in tbe
Theres your MAJOR/MAIN problem.
Old Jul 26, 2008 | 04:38 PM
Ebirns99's Avatar
I actually just installed a test pipe today and i'm having the same problem
Old Jul 26, 2008 | 04:39 PM
SpoolnupTuning's Avatar
have you checked for boost leaks??? could be the tune but if it just started out of the blue then it probally isnt the tune!
Old Jul 26, 2008 | 04:43 PM
SILVERnSLOW's Avatar
Did it start happening after you changed something or was it a random thing?
Old Jul 27, 2008 | 01:35 AM
Ebirns99's Avatar
when i took it to ams they checked for boost leaks cause the cams did not make the power they should have so they took the cat off and put it on the dyno and found it was the cat that was holding the power up. i got the test pipe easy install and than when i drove it, it would not hold boost and than a would flutter. it was one the dyno for a tune 3 days prior to test pipe install.
Old Jul 27, 2008 | 01:59 AM
all4bspinnin's Avatar
+1, i would check the car for boost leaks
