low boost, cylinder misfire?
I drive a 05 evo VIII. It has a turbo back exhaust system, intake, mbc set at 21 psi, and ecu reflash. I recently was driving home from work and my check engine light was on after I tried a 3rd gear pull onto the freeway. I floored it and the car hardly moved at all. I looked at the boost gauge and it would go only to 16 psi. Read the code and it was random/multiple cylinder misfire. I researched on the forum about this and people say that this can happen with evo VIII and isn't that uncommon. i cleared the code and the car hasnt thrown a code since, but still only boosts 16psi. I was thinking it switched to a more conservative map when it threw the code. do i need to get another reflash or can i just raise the boost?
boostfr3ak
May 1, 2009 12:14 PM
