ticking or popping sound when taking off from a stop with the wheel turned
Old Aug 30, 2008 | 09:36 AM
r.m.s.'s Avatar
I agree its your boot over your cv joint that failed leading to the clicking sound, let us know if the dealer covers that?
Old Aug 30, 2008 | 05:48 PM
MikeIsBoosted's Avatar
Update :
I went to AWD Motorsports yesterday for an inspection, and CWill found nothing out of the ordinary. Everything checked out ok. He said he found that some bolts were a little loose, and the height adjustment ring on the coilover was a little loose. He tightened everything up and no noise since!
Old Aug 30, 2008 | 06:16 PM
sblvro's Avatar
I noticed that too but just ignored it and it went away
Old Aug 30, 2008 | 07:10 PM
92gsxbaltimore's Avatar
I have actually been slammed busy, so sorry for no updates as of yet. I will be changing my oil tomorrow, so I will see if I see anything out of place and give an update
Old May 12, 2009 | 09:11 PM
Evolution7GSR's Avatar
anything ever happen with this?! this is the exact problem i have and need some help! my cv joints look fine, no rips.
Old May 13, 2009 | 05:20 AM
The sound has gone away, but my clutch is slipping, so I think it may have been associated with the clutch. I took it to the dealer to have them look at it and I could not reproduce the sound. For the last two moths or so, I have not heard it. I'll update when I throw in the new clutch.
Old May 25, 2009 | 10:28 PM
thats so weird.... mine has been doing it for a while but its been getting worse.. was doing it before i did my clutch last month and still did it after... getting so annoyed with this!!! i double check my cv's they look perfect... axles are def set... i have no clue what is causing this... please help!
Old May 28, 2009 | 10:09 PM
bump for help
Old May 31, 2009 | 01:40 AM
OZrallyracer's Avatar
Bump for help here too! I have the exact same problem and can't figure it out... already crawled under there and the cv boots look fine... it's coming from the front left wheel area... the axle looks fine as well, I was thinking maybe a wheel bearing but only having it happen with the wheel turned at low speeds to 10mph or so leads me to believe that that can't be true, otherwise it would happen at speed as well when turning the wheel that much... ANYONE have this problem and get it fixed?
Old Jun 2, 2009 | 11:16 PM
another bump for an answer..
Old Jun 2, 2009 | 11:31 PM
Domolution's Avatar
Any updates?
Old Jun 4, 2009 | 09:08 PM
i wish there was an answer..literally driving me insane.....
Old Jun 19, 2009 | 05:41 AM
SuperchargedGTZ's Avatar
is your car vibrating too. My car does all of this when I turn sharply. I know that it is my rear diff binding up. I need a new one
Old Jul 15, 2009 | 03:47 AM
Jk's03EVO's Avatar
You're talking about binding as in a dragging feel when turning right?
Old Jul 26, 2009 | 10:51 PM
utripin's Avatar
May be the bolts holding the two halfs of the center diff.
