Evo 7 Clucht Options
I Have An Evo 7 I Need A Clutch Kit Beside Spec Clutch Any Other Clutch Kit Out There Someone Told Me Just To Buy The Evo 8 Clutch Kit And I Should Fit Is This True Is The Flywheel The Same
im so cofused 11 sec evo 7 , because i called act and they told me that they sell an evo 7 clutch kit and an evo and they told me that they r not the same, also spec has different prices and part number 4 the evo 7 and 8 clutch ....
im afraid that if i buy one from the evo 8 something can go wrong
HELP.............
HELP.............
^any evo 8 clutch would work in your evo 7..simple.
This includes flywheel's and pressure plates etc...
as for the exedy stage 2..."evo gerard" may be able to help you better in that respect
no no no!!!!
check my signature...
I am using a Tilton clutch..and guess what..tilton doesnt make a clutch kit for the evo 7
i bought the whole assembly from Tilton for the EVO 8....yes that's right...the evo 8!
clutch, pressure plate AND flywheel for the EVO 8....and it all works perfectly on my Evo 7...
I can only give you my word on this...not in a position to prove it any other way
on exedy's website u'll see the same part number for the evo 7 & 8
. also they have a spec sheet with the torque capacity off all there clutches specific to the evo. so check it out and that would give u an idea of the the capacity of the clutch. i have a stage one and when that needs to change i am goin straight to the twin HD. hope u fine the info u want. and remember evo 8 and 7 clutches (and a host of other parts) are the same.
