Load differences per gear
Old Jul 30, 2008 | 07:18 PM
RazorLab's Avatar
I've seen some assumptions on EvoM that load varies gear to gear. From a ton of datalogging I've known that this is not always a correct assumption.
Today I had some extra time on my hands and was working on my personal Evos tuning, so I decided to go through the gears and get some logs to show.
My one disclaimer is that I do most of my tuning and work with RPM based ecu-controlled boost Evos. MBC controlled Evos might be different.
Log of 1st through 3rd gear:
Another log of 2nd through 4th gear:
As you can see, the load only varies a very small amount, but not enough to land the tune into different load cells per gear and rpm. In this example, it stays in the same fuel and timing cells gear to gear.
Boost was logged with a JDM map sensor and the log reflects this. The JDM map sensor has no smoothing in logging so you might see some "blips" in the boost in the log.
Old Jul 30, 2008 | 07:30 PM
nightwalker's Avatar
I'm just assuming, but I don't think a MBC is the same gear to gear.
Old Jul 30, 2008 | 07:33 PM
kouzman's Avatar
thats cool info!!!
Old Jul 30, 2008 | 07:44 PM
EvoBroMA's Avatar
wow awesome info.
is this using direct boost control via jdm map sensor? Hopefully not.
also more importantly - is this with lean spool disabled?
stock bcs FTW!!
Old Jul 30, 2008 | 07:55 PM
RazorLab's Avatar
Originally Posted by dexmix
wow awesome info.
stock bcs FTW!!
GM 3port solenoid and direct (PSI-target) boost control using 3 bar map sensor. However no error correction kicked in during the above logs. Straight un-molested tuned WGDC.
Lean spool is disabled. 11.5 straight in each gear after tip-in enrichment that I am still working on.
