3582HTA vs 6265 Dyno Comparo
Old Aug 6, 2008 | 10:07 PM
  #61
Zeus's Avatar
Ok, yes, yes a hack job of an edit I know. However, if you guys what to talk about things other than related to post #1, start your own thread. We need to clean up and keep relevant info in the proper threads. No wonder the newbies can't find what they are looking for with a simple search.
Old Aug 6, 2008 | 10:28 PM
  #62
dragers's Avatar
could you do a comparison between the 88HTA and the 3582HTA, please
Old Aug 7, 2008 | 12:40 AM
  #63
haseeb's Avatar
i wana know this also
Old Aug 7, 2008 | 06:37 AM
  #64
Crzbiasmr's Avatar
+ juan chad
Old Aug 7, 2008 | 08:21 AM
  #65
DynoFlash's Avatar
Originally Posted by dsm25psi
if 6265 spooled a lot later and made little less on the dyno i really dont think that the 6262 will be even close to same power as the hta but we will see how it will spool.
IMHO the first test that needs to be done is the 62/62 against the regular GT35 to see if the 62/62 can give Gt35 like performance at a slighly less expensice price point which from what I have been told was the idea.
It is silly to compare a entry level inexpensive unit like the 62/62 against the premium priced HTA - well depending on the results it may not be that silly
Test away!
Old Aug 7, 2008 | 08:25 AM
  #66
PATRICK B.'s Avatar
Test away!
Very good point Al but i think the whole comparo might be thrown out since i think the whole idea is to test the new billet comp wheels heads up in as similar as possible size wise.
I do think it would be great to see though the diff between non billet wheels in the reg 35r vs both hta and 6262
Old Aug 7, 2008 | 09:02 AM
  #67
StevenStarke's Avatar
Test away!
your doing the same as I did and confusing the 6262 with the 6162. The 6162 is the 35R equivalent and is a lil bit cheaper
Old Aug 7, 2008 | 10:52 AM
  #68
Migsubishi's Avatar
My opinion is that we obviously know the 62/62 with the AMS custom compressor housing out performs the HTA37R, I believe they already performed that test.
We also know from their testing that the 62/62 with the AMS custom compressor cover out performs the standard GT35R with 150-200rpm more lag, I believe they also performed that test.
Which leaves the last question, will the 62/62 with the AMS custom compressor housing out perform the FP HTA35R, I believe this is the test we have been waiting for.
In speculation, I would say no, will it make a little more peak power, well if the flow characteristics are right, it is a bigger turbo so why not...
Where will it make this increase in power, I would say at peak rpm as most bigger turbos do... Again this is my speculation and not to be taken to heart.
Old Aug 7, 2008 | 11:06 AM
  #69
ForcedPerformance's Avatar
Personally I don't think a different compressor housing is going to make the 62mm PTE wheel create more power. But I suppose that would be the reason to do the test. I don't have it in my budget to run the test, sorry.
Old Aug 7, 2008 | 11:18 AM
  #70
AWD Motorsports's Avatar
What we also would like to know is if the standard precision cover makes any difference over the AMS cover also.. PTE 6262 with ported cover may have the same results.,.
Old Aug 7, 2008 | 11:31 AM
  #71
PATRICK B.'s Avatar
Yup....yup.
I think it's important for those that don't go through AMS.
Old Aug 7, 2008 | 11:45 AM
  #72
Migsubishi's Avatar
I agree, I was just being facetious about their secret covers. The only difference I can possibly see it having to do with is in its surge department.
Old Aug 7, 2008 | 12:12 PM
  #73
konstantinosIX's Avatar
I can not believe that AMS can't do (did) a test back to back with HTA and 850R...
They already did it and they already know the truth... maybe...
Old Aug 7, 2008 | 12:17 PM
  #74
Crzbiasmr's Avatar
Who cares? Its up to them if they want to do compare the two turbo's. I don't know why everyone wants to throw there two cents in about it. Maybe they will run a test or maybe they won't. It's up to them want they want to do.
Old Aug 7, 2008 | 12:58 PM
  #75
I think that if 850 was better they would had post the results.... probably... just like the gt35 back to back test...
Don't you think???
