Cam/valve cover questions
Old Aug 18, 2008 | 02:52 PM
NJ_EveOhVIII's Avatar
some time this week i will be installing my cams (finally) ive read the installs over and over again..i wont be using the tensioner tool can someone eliberate on how to mark the gears and keep them in place
how do you keep the gasket on the valve cover everyone says it just stays there?
anything else i should do before or after the install (bleeding the valves i know about)
Old Aug 18, 2008 | 03:15 PM
lemmysports2's Avatar
go to- http://www.evomoto.com
they'll walk you through it, and you cant bleed valves
Old Aug 18, 2008 | 03:19 PM
Curt@MrLed's Avatar
Former Vendor
Judging by your statement let a qualified person do it. I have done many installs and this is not a thing you want to learn on.
1. You cant bleed valves.
2. You need a tensioner tool no matter how you do this.
3. The gasket comes off or stays there it doesnt matter.
4. The evomoto write up is great, but its not perfect. There are a few things it doesnt explain.
