Cams for a 9?
Old Aug 20, 2008 | 06:59 AM
TTP Engineering's Avatar
You dont need vsprings on kelfords, however over 7900rpms it would be a good idea.
Old Aug 20, 2008 | 07:03 AM
JordanS4's Avatar
Originally Posted by brandEvO
the person (i think) helping me put them in is a Mitsu tech so thats helps. He'll probably make me change the springs lol.
It's not as easy as it sounds.
Old Aug 20, 2008 | 08:00 AM
This would be correct. The head needs to come off the car without expensive specialty tools and a high capacity air compressor.
Old Aug 20, 2008 | 04:47 PM
skk72's Avatar
I dont believe you need valve springs if you run tomei poncam 260 10.7 in and 10.2 ex lift. once you go up to 11 plus you will need to pick up some valve springs. tomei poncam was made for simple drop in cams. no other modification needed.
Old Aug 20, 2008 | 07:22 PM
thatdudety's Avatar
just do the kelfords... an aggressive cam. people say that they even prefer the gsc s2 than the s1's on stock turbo. very ssimilar to the kelfords
Old Aug 20, 2008 | 08:04 PM
DG Motors's Avatar
What is wrong with Cosworth? I did not see those listed...
Old Aug 21, 2008 | 01:51 AM
ronitlancer's Avatar
I am looking into getting Cams for my IX MR soon also, whats the best? Also dont plan on racing or dragging soon so prolly wont change my springs
Old Aug 22, 2008 | 03:28 PM
skk72's Avatar
cam
My friend with MR is waiting on Tomei 270 , I believe they offer 260 currently
http://www.tomei-p.co.jp/inf/pdf/nri105_e_letter.pdf
Old Aug 22, 2008 | 06:05 PM
SixOneNine's Avatar
If you're not changing out the springs and retainers, have your tuner (or yourself) set the rev limiter to 7700-7800 just in case.
Old Aug 28, 2008 | 02:53 PM
Not a bad idea, could I run the GSC S2s on stock springs/retainers? I dont really rev past 7k and rarely even get that high, I don't plan on tracking anytime in the near future and I don't need to shift at 7800 on the street
Old Aug 28, 2008 | 03:34 PM
EMC's Avatar
EMC
I've read nothing but good reviews on those Kelfords. Deff a cam to consider.
Old Aug 28, 2008 | 04:08 PM
We have the country's Kelford stock in house...
Let us know if you are interested in picking up a set.
We do have one rare set of a special model available we were saving for testing on a stock turbo, that we might even let go.
Old Aug 28, 2008 | 04:28 PM
projectevo9's Avatar
What's up Scott
Special Model??? Sounds good. I think I want those. What 's the difference?
Old Aug 28, 2008 | 09:35 PM
thatdudety's Avatar
yea what is the difference?
Old Aug 28, 2008 | 09:46 PM
Jeff_Jeske's Avatar
I would tell you not to change the cams until you upgrade the turbo.
Most gurus will tell you that the stock EVO9 cams are comparable to the HKS 272 EVO8 cams. They should be plenty good for maxing out the stock turbo.
I would focus on more boost, airflow, or octane prior more cam.
