reverse block
Old Aug 21, 2008 | 06:17 PM
evo4l's Avatar
Exclamation reverse block
so i have trouble getting my evo in reverse. When the car is cold i sometimes cant get it in at all so i will have to push it. lol but when the car is warm it usually always goes in. i will ease ahead in first and then try and put it in reverse and that only works sometimes. i need help.
Old Aug 21, 2008 | 07:21 PM
rolly1818's Avatar
Registered User
does this happen when your car is cold only?
when my car is cold the gears are very notchy. when i drive for a while it goes in easily. i did some reading and got some suggestions on here that i used the wrong tranny fluid.
i dont think this is your problem but check it out.
Old Aug 21, 2008 | 08:00 PM
cfdfireman1's Avatar
change the trans fluid and adjust the clutch
Old Aug 21, 2008 | 08:03 PM
evo4l's Avatar
well it mostly happens when the car is cold but once and a while when it is warm i still have troubles but i can eventually get it in by easing ahead and then throwing it back in reverse. i used BG syncroshift II for my tranny and thats what everyone told me to use so i think everything was done correctly. I wonder how much it would cost to replace reverse?
Old Aug 21, 2008 | 08:11 PM
evo4l's Avatar
i had my clutch replaced not that long ago with an ACT Extreme w/ flywheel is it a possibility that it is set wrong? how do you adjust the clutch?
Old Aug 21, 2008 | 08:14 PM
rolly1818's Avatar
Registered User
any shop can do it for you...or are u a DIYer?
check the service manuals
Old Aug 21, 2008 | 09:00 PM
evo4l's Avatar
well if it is an easy job i would do it myself because my shop is and hour away?
Old Aug 22, 2008 | 04:12 AM
rolly1818's Avatar
Registered User
its not a hard job, i would say novice difficulty. but if your not sure take it to a shop to be safe they will know exactly where to set it at.
you got the service manual for your car right?
Old Aug 22, 2008 | 07:01 AM
evo4l's Avatar
yea i have the service manuel. y? it wouldn't say anything in there would it?
Old Aug 22, 2008 | 07:21 AM
rolly1818's Avatar
Registered User
to be honest it says everything in there lol...
damn long though. but its good weekend reading
