is that safe?????
Old Aug 22, 2008 | 08:40 PM
speedy evo's Avatar
is that safe?????
fixed the problem
Old Aug 22, 2008 | 08:43 PM
sparky's Avatar
Can you give your detailed modlist please? Also, some engine bay pics would be nice if possible.
Old Aug 22, 2008 | 08:45 PM
staatz's Avatar
You will blow up.
Old Aug 22, 2008 | 08:47 PM
SixOneNine's Avatar
NOT safe. The car is basically making "unlimited boost" when you disconnect the hose from the wastegate.
Old Aug 22, 2008 | 08:48 PM
denver's Avatar
please clarify what you are doing?? Are you disconnecting the MBC from your waste gate actuator? If so, then of course you can boost more, you have no control of your boost pressure, your car is boosting as much as it can... with no control....<=engine goes BOOM
How many PSI are you hitting and how long have you been doing this?
Old Aug 22, 2008 | 08:52 PM
Protostar1's Avatar
kaboom! the wastegate needs to dump pressure so you dont overboost and blow your motor up. connect it back up!
Old Aug 22, 2008 | 08:57 PM
speedy evo's Avatar
i am currently running 28 psi but i want to hit more but the car just wont do it, so i decide to disconnect the MBC so now i can hit 30 psi. only opver 2 psi.
Old Aug 22, 2008 | 08:59 PM
griffeyr's Avatar
i had an eclipse with a super 16g turbo, pulled the hose off the wastegate, and took off like a bat outa hell lol you may or may not blow it up, but i wouldnt do it
Old Aug 22, 2008 | 09:01 PM
denver's Avatar
what fuel are you running? And is your car tuned for this? Mod?
Old Aug 22, 2008 | 09:04 PM
SixOneNine's Avatar
How are you monitoring boost? Just because it says 30psi on the boost gauge does not mean it's boosting that much. Again, you can't control boost when the hose from the wastegate is disconnected.
Old Aug 22, 2008 | 09:12 PM
Mellon Racing's Avatar
lol hopefully this is a joke...too funny.
Old Aug 22, 2008 | 09:14 PM
BlueDemon's Avatar
LOL, who told you that this was going to be a good idea so I can send him an E-SLAP!
Yeah, the whole thing of having a wastegate is to control the amount of boost by stopping the turbo from overboosting and blowing up your engine in the process. Think about it!
Old Aug 22, 2008 | 09:19 PM
speedy evo's Avatar
fixed the problem
