tubular manifold
Old Aug 27, 2008 | 06:40 PM
Dragking2189's Avatar
tubular manifold
here goes another thread about tubular manifold .... i have an custom made tubular manifold , the manifols has no heat coating or podwer coating what so ever.... and i dont want to heat coated do u think heat wrapping it will bw a good idea please guys help me im kinda fustrated ... thnaks lots
Old Aug 27, 2008 | 06:43 PM
Craig King's Avatar
Heat wrap will keep more heat energy in the manifold, and in turn, more energy to your turbo. More energy = more power. If you can heat wrap it, I would. Not to mention it'll help keep underhood temperatures down too.
Old Aug 27, 2008 | 06:45 PM
AWD Motorsports's Avatar
post pics of the manifold.. Coating is your best bet.. Heat wrap will trap the moisture and can ruin the manifold..
Old Aug 27, 2008 | 06:51 PM
hamx0r's Avatar
true
Old Aug 27, 2008 | 09:06 PM
sparky's Avatar
Heat wrapping an exhaust manifold can be a fire hazard. If that material becomes oil soaked it can catch fire, especially at 1350-1550 F* surface temps. It happeed to a friend's car.
Old Aug 28, 2008 | 08:53 AM
srajeremy's Avatar
go for it wrap the sucker
Old Aug 28, 2008 | 02:37 PM
Craig King's Avatar
Only if it's applied incorrectly.
Again, if done incorrectly.
Old Aug 28, 2008 | 02:41 PM
Thegame's Avatar
I would suggest the swain tech coating
Old Aug 28, 2008 | 02:45 PM
how do you suggest doing it that will make the material not absorb moisture and cause the the wrap to deteriorate the piping??
Old Aug 28, 2008 | 02:52 PM
Craig King's Avatar
I'm not an advocate of heating wrapping, but if done correctly, it can be quite effective. There are 2 different coatings you are supposed to apply in addition to the actual heat wrap material. The first is an adhesive coating, to make sure the heat wrap sticks to the manifold. After you apply the wrap tightly, there is a second coat of spray-on sealer, that basically is a high-temp water proofing. This keeps the heat wrap from absorbing moisture and retaining it.
However, very few people actually follow the instructions for proper heat wrapping, and thus, you get the results mentioned. I've seen a lot of guys on here just wrap the heat wrap around their manifold, then use a hose-clamp to hold it on.
Old Aug 28, 2008 | 06:37 PM
Spoolin18's Avatar
I would never think of heat wrapping a daily driven car with a tubular manifold. I've seen way to many manifolds crack because of the amount of heat, plus moisture being trapped inside. This is something I would consider doing on a full-out race car, but def. not something driven on the street. Just my .02 cents.
Old Oct 14, 2008 | 07:48 PM
STIKiller4G63's Avatar
I heat coated it and then wrapped my manifold really tight and then sprayed the wrap with a DEI silicone spray to keep the wrap from getting any kind of moisture...works great I think
Old Oct 14, 2008 | 11:50 PM
JC evo1's Avatar
just wondering why you dont want to coat it?
Serginio
14
Jul 24, 2017 08:14 PM
cmoore
Feb 7, 2016 04:27 PM
jwwu
19
Jul 3, 2011 11:00 AM
jasonrp15
17
Apr 1, 2008 07:38 AM
FlyNavy
Jun 27, 2005 03:11 PM
