problems shifting in to reverse.
Old Sep 10, 2008 | 05:50 PM
SLO-EVO's Avatar
Originally Posted by Knguyen228
Mitsu installed the clutch so it was there fault.
take your car back, tell them the problem, and demand they fix it... theres no reason that they should be giving your car back to you in less than perfect condition...
Old Sep 10, 2008 | 05:55 PM
Knguyen228's Avatar
I did. didn't cost me a dime.
Old Sep 10, 2008 | 05:59 PM
SLO-EVO's Avatar
ooh... i was under the impression that you were still having the issue....
Old Sep 11, 2008 | 01:28 AM
Short-Bus's Avatar
im still having the issue though lol
Old Sep 11, 2008 | 01:35 PM
Short-Bus's Avatar
bump for serious need of your help
Old Sep 11, 2008 | 08:31 PM
Short-Bus's Avatar
some guys one azawd.org are saying that it could be a throwout bearing issue but i replaced that does anybody else want to shed any light on the situation?
Old Sep 15, 2008 | 06:50 AM
Short-Bus's Avatar
bump
Old Sep 15, 2008 | 07:07 AM
cfdfireman1's Avatar
What does it do, grind or just not go in?
Old Sep 15, 2008 | 04:25 PM
Short-Bus's Avatar
basically it feels like the car starts to move forward when i try to go into first it will not go in unless i rev the car a bit and even then sometimes it will create a small grind, this is the same with all the gears
Old Sep 15, 2008 | 10:49 PM
rEVoLed's Avatar
Mine doesn't like to go into reverse or any gear for that matter when the car is completely cold, also thats when the clutch drag the most. Once the car is warm, it shifts perfectly fine. This started to happen to me after I temporary welded pp to the disk but since you have a new clutch I have no clue. Is the clutch broken in yet?
Old Sep 16, 2008 | 06:22 AM
Short-Bus's Avatar
yea the clutch is broken in but even when its warm it shifts better but still will not go into gear
gimpydingo
13
Mar 16, 2013 06:39 PM
VistaBlueGT
Jul 2, 2011 05:14 PM
Charlie-Y
May 21, 2011 08:57 AM
Tractionlimit
14
May 27, 2009 07:26 PM
Rnm
Jun 22, 2006 04:26 PM
