1000cc injectors at 650 help
Old Aug 29, 2008 | 06:29 PM
Gbrownn08's Avatar
can anyone give me some help as to why my 1000cc injectors want to be at 650? The car idles at 14.7-15 for air/fuel..has anyone else had this with their cars? I have an AMS35R kit also
Old Aug 29, 2008 | 07:03 PM
kkarim's Avatar
if you are talking about the injector scaling in ECUflash, you will have a lot more help by posting in the ecuflash forums.
and when scaling your injectors, you should be looking at the fuel trims, not the closed loop, because after the trims have settled, your afrs will be around 14.7.
Old Aug 29, 2008 | 07:09 PM
kkarim's Avatar
you need to check out your latencies. they are probably too low for your injector size.
there is a guide on how to rescale your injectors on the ecuflash section. it's very useful. you might even find scalings and latencies for the injectors you have.
did you tune your car for WOT yet? are you having to remove a lot of fuel from the maps at WOT?
Tevo9K
Aug 30, 2011 07:16 PM
Hiboost
36
Jul 16, 2010 07:41 AM
Aliengotpsi
22
Nov 4, 2008 09:55 AM
Gbrownn08
Sep 8, 2008 08:41 PM
ak1
Feb 23, 2005 04:40 PM
