exhaust tip question
Old Aug 30, 2008 | 01:59 PM
mugen777's Avatar
Maybe this is a dumb question if I am getting a exhaust tip for a 3" pipe do i need to get an exhaust tip that has a 3" inlet to get welded on?
imagine this exhaust without the tip thats what i currently have, I just wanna make sure i buy the right size tip that I need
Old Aug 30, 2008 | 02:21 PM
sna08's Avatar
Not sure exactly what your asking but if your running a 3" diameter pipe from the Cat then you should get a 3" exhaust tip thats 3"... otherwise the back pressure will differ from stock... (can anyone elaborate more?)
Old Aug 30, 2008 | 02:24 PM
mugen777's Avatar
well what im doing is running a full 3" straight pipe but just wanted to get an exhaust tip like so
http://www.jegs.com/p/Hooker/744873/10002/-1/10255
just wanting to make sure i get the right size i have a 3" straight pipe exhaust i am assuming i need a 3" inlet size tip right? to get welded i just didn't want a raw pipe
Old Aug 30, 2008 | 04:07 PM
sna08's Avatar
I dont wanna bash on what you are trying to do but i see no point in an exhaust tip like the one on that page. fwiw, I like the raw looking tip. do u have an exhaust system that comes with a tip? or are u using the stock evo exhaust?
Old Aug 30, 2008 | 04:10 PM
mugen777's Avatar
heres what i did i bought a full 3" turbo back exhaust with test pipe...
But i took it to an exhaust shop today and got it cut right after the rear hangers before the muffler and had a 3" piece welded (muffler delete) here ill show ya a pic and get your opinion, sounds sick
Old Aug 30, 2008 | 05:01 PM
mugen777's Avatar
BUMP for added picture
Old Aug 30, 2008 | 07:51 PM
EvoDom's Avatar
you would have to get a 3" tip and have the exhaust shop do the work. yes get a 3" inlet.
Old Aug 30, 2008 | 08:09 PM
srajeremy's Avatar
at least 3" strange idea? why do you want a tip instead of just leaving the pipe?
Old Aug 30, 2008 | 08:15 PM
JYD's Avatar
JYD
uhh the whole reason you buy an aftermarket exhaust, is to alter the back pressure. you have the chewbacca theory in full effect with what you just said.
Old Aug 30, 2008 | 09:18 PM
hytek369's Avatar
Old Aug 30, 2008 | 10:58 PM
Kracka's Avatar
If you have 3" piping you need a tip with a 3" inlet.
Old Aug 30, 2008 | 11:22 PM
sidtheretard's Avatar
Just Get A 3" Exhaust Tip Nd Ull Be Fine
Old Aug 30, 2008 | 11:24 PM
What Kind Of Exhaust Is That Neway??
Old Sep 5, 2008 | 06:48 PM
Brokenevo's Avatar
3" all the way
