Need Help Today!!! Swapping Turbos On 2003 And 2006
sup yall. I have a 2003 evo with the stocker on it and my friend has a evo ix with the stock ix turbo, megan manifold, and megan o2 housing. We are going to swap turbos, manifolds, and o2 housings today. He has ordered a turbo kit and just needed something to ride on just in case he needs to drive it. (luckily he has two other vehicles). I am hoping/wanting to be able to take everything off in one piece.
Will I encounter problems fitting my stock turbo, manifold, and 02 housing on his evo ix?
What would yall suggest that I do about the oil lines? I know that i will need his oil lines to put his evo ix turbo on my car. Im concerned with my oil lines going on his car.
Is there anything/problem that anyone can think off with this swap?
All info welcomed. We will get started about 2pm EST. thanks yall
werd. so i understand that I will have to modify(bend) my oil lines to put his set-up on my car. Will I have to do any modifications to his oil lines to put my old set-up on his car?
You 2 should be fine man. Just be carefull when bending that you dont pinch a line. And make sure the bolt holes for oil line up right. Just make marks.
As far as the 8 on his 9 minor if any bending.
yeah im worried about "pinching" the lines too. which oil line is going to be the one that requires modifications? I know this is all last minute but my friend is really hooking me up.
