help! car problem bad sensor maybe?
when i start my evo it shoots out clouds of black smoke and the idle is unstable and i cant pass 2,ooo rpm on full throttle. the spark plugs is all black and smells like fuel. all spark plug ignites and works. change the maf sensor, didnt help. i believe a sensor is bad but i dont know which one? crank sensor,cam sensor,o2,? it seems to have a misfire and the timing is off? dont know what though? there is spark so im not sure of crank sensor. cam?maybe... what would a bad o2 do to my
car? anything would help. thanks
Josh
Josh
really stupid but did you check the obvious? Go double check that all your IC pipes are on. I know its stupid but that will give black smoke. idle will not be good, and cant go wot obviously
Josh
