How much power can timing get you? went to the dyno to find out!
Old Sep 12, 2008 | 10:05 AM
ExViTermini's Avatar
Originally Posted by crcain
I'd like to see a proof done, in this fashion, of a tuner explaining why a fully built Evo with 35R should run 22 psi on pump gas
I mean is anyone left who still beleives 22 psi can be the right pump gas boost for your typical fully built 35R car? People run 22 psi on the stock turbo safely. And as Ted has described in this thread, your tolerance for ignition advance increases as peak torque / max boost occurs later. And also the more efficient compressor and larger hotside also contribute to higher ignition advance tolerance.
So someone explain to me why we still see fully built 35R cars only tuned for 22-23 psi on pump gas?
Maybe because some people don't want their cars to make 600whp all the time. Personally I like utilizing the car for some backroad action, and without a ****load of money in the suspension and tire setup 600hp is f**king useless. Not to mention its just that much more stress on the engine.
Old Sep 12, 2008 | 10:37 AM
SloRice's Avatar
Having a 35R for some "backroad action" is like hunting a squirrel with a nuclear weapon. It's a bit overkill.
Old Sep 12, 2008 | 10:42 AM
Marshall O's Avatar
In that case, why not stick with a stock turbo, or a green and make 350-400? If you have a 35R, than you should have the supporting mods to run it, otherwise what is the point? Now, having a street tune and a track tune are two different things. But still, 22 PSI on a 35R is like running 12 PSI on a stock turbo in a sense...
Old Sep 12, 2008 | 11:08 AM
RAbishi's Avatar
That's pretty cool to see the difference on a dyno sheet of how much of a difference it makes. Very cool!
Old Sep 12, 2008 | 11:12 AM
crcain's Avatar
Yes but I'm saying you should be tuned for 28-32 psi even if you don't run it everyday.
I'm just an amateur but from what I've learned over the years, thanks in part to the good people on EvoM like TedB and such, it seems like it is provable, that whatever you deem safe boost on stock turbo, can be higher with a larger turbo, while keeping the exact same safety margin, and all else being equal. It's not a guess it's fact... *I think*.
I would have so loved to see the OP of this thread, do a test, while listening or logging knock, to keep increasing boost, while retarding ignition timing, on pump fuel. My guess is he could get to around 35 psi on pump fuel safely, and probably around 30 psi he would end up not making much more power.
Old Sep 12, 2008 | 11:54 AM
Marshall O's Avatar
35 PSI on pump with no meth/alcohol injection? Not sure about that one...
Old Sep 12, 2008 | 11:58 AM
EVO8_PR's Avatar
I did run it on pump 93 octane fuel at the same 28 psi here are is comparison of the race fuel vs pump gas dyno run.
[IMG][/IMG]
Old Sep 12, 2008 | 12:07 PM
SloRice's Avatar
I've ran 33psi on pump gas and I could have ran more too based on the knock voltage in the AEM.
Old Sep 12, 2008 | 12:13 PM
EVO8_PR's Avatar
What knock voltage do you get?
Old Sep 12, 2008 | 12:15 PM
SloRice's Avatar
220, 221...whatever it takes.
Old Sep 12, 2008 | 01:46 PM
steelcityevo8's Avatar
???? what does that represent.
AEM knock voltage is 0-5 volt range
Old Sep 12, 2008 | 01:56 PM
dudical26's Avatar
Thats why you have a gas pedal and not an on/off switch. If you want less than 600hp use less throttle.
Old Sep 12, 2008 | 02:05 PM
93 3gt vr4's Avatar
I've been wondering this same stuff since im in the middle of tunning my car. I started a thread timing vs boost but know one chimed in. I was under the impression that boost made more power than timing as long as the timing is somewhat decent and not over agressive with higher boost?
Old Sep 12, 2008 | 02:10 PM
EVO8_PR's Avatar
I've been asking my self the same question
Old Sep 12, 2008 | 03:09 PM
SloRice's Avatar
I guess you guys aren't early 80's movie buff.
