Greddy Profec B
Old Sep 13, 2008 | 03:35 PM
northsydevo's Avatar
Greddy Profec B
Whats a good setting from high to low. I like to know what does each setting does. Thanks in advance.
Old Sep 13, 2008 | 04:07 PM
Duh Panda's Avatar
is that just the Profec B? i have one myself... low setting seems to go from 9lbs at the lowest and the top to like 15ishlbs High setting goes from 15ishlbs to like 35ishlbs ? i
Old Sep 13, 2008 | 04:24 PM
JRB_EVO's Avatar
Try this setting for around 22psi
Set boost - 55%
Gain 8-9%
Warning - Whatever you like
Start Boost - 1.00 Bar
Limiter - Whatever percentage you want
Also do a search on the forum that there is a very good thread with many settings people have suggested!!!
Old Sep 13, 2008 | 05:04 PM
what about peak?
Old Sep 13, 2008 | 05:11 PM
and are these setting in high or low? or does it matter?
Old Sep 13, 2008 | 05:13 PM
1NastyMR's Avatar
I believe it matters my low setting is 25% set boost 5% gain 50 setgain warning doesnt matter and i have limiter disabled
Old Sep 13, 2008 | 05:23 PM
JRB_EVO's Avatar
The profec B Spec allows you to have 2 different boost settings, a high one and a low one. The low one is my winter mode map which gets me roughly 20psi, for if I ever have to get on it during the winter. The high one is the amount of boost I'm tuned for.
That is the way I would set up the EBC if I were you.
