Transfer Case had no oil
Old Sep 15, 2008 | 08:05 AM
tvor's Avatar
well, almost no oil.
I changes the fluid in it about 7500 ago and went to change it again, but there was almost no oil in there. Supposed to hold .58 quarts and maybe .1 came out....
Where could this be leaking? I don't hear any whining or feel anything strange from it so I hope it's not terribly damaged, but I need to get this fixed. I filled it back up with Diaqueen and I'm hoping for the best right now.
Old Sep 15, 2008 | 08:08 AM
rcheung's Avatar
Is your axle ok with the pins still attached?
Old Sep 15, 2008 | 08:21 AM
Massimo Power's Avatar
when i first did my diff it looked like only a tiny bit came out but when i put some redline in it seemed like even then it was less than half a quart...
but i think you sould be fine
Old Sep 15, 2008 | 08:36 AM
tvor's Avatar
Axle seems to be ok, didn't see anything wrong with it....
It took about .3 or .4 quarts of fluid when I filled it...maybe a bit less...
Old Sep 15, 2008 | 08:37 AM
Gary@MellonRacing's Avatar
does any one know how much oil does the transfer use and what kind can i use
Old Sep 15, 2008 | 09:14 AM
tvor's Avatar
http://www.evomoto.com/tech_info.php?tPath=2&tech_id=25
Old Sep 15, 2008 | 02:20 PM
Evolessfornow's Avatar
Dumb question but it's worth asking. Was the car level when you drained and filled the t-case?
Old Sep 15, 2008 | 06:13 PM
Aman's Avatar
should take about .6 qt
Old Sep 15, 2008 | 07:08 PM
tvor's Avatar
Yeah. I raised it to take the plug out, then dropped it to the ground. Just a trickle when the drain plug was pulled and barely more when it was lowered. Maybe it needs to be sent to TRE
Old Sep 15, 2008 | 08:33 PM
Jeff_Jeske's Avatar
How much did it take when you filled it back up?
I've had a couple of EVOs that simply wouldn't drain all the fluid. When you start doing the clutch and yank the xfer case it will spill all over.
Old Sep 15, 2008 | 08:38 PM
whitey4d's Avatar
tre has a pretty long disclaimer that after filling the case the car needs to be driven over 25 mph then refiller again. Either It didnt all drain out of it or was under filled last time.
There would be a huge mess if it were leaking externally.
Old Sep 15, 2008 | 08:56 PM
tvor's Avatar
It hasn't been sent to TRE before...it's all stock. I was just thinking that maybe it needs to be rebuilt. I messed with the clutch and all that good stuff and lowered the passenger side only as well to see if the fluid would come out.
It took about .4 quarts after I drained it, but less than .1 had come out when it was drained, so something is going on.
