4g64 setup. JDM evo VII water pump, no adapter
Old Sep 24, 2008 | 07:54 AM
bab090's Avatar
hi guys, i am about to do project by 4g64 block with JDM evo VII head, and as i know, you guys (US e8 owner) use special adapter plate with your evo water pump to fit with 4g64 block, and i thought it would be same with my JDm e7, but when i compare with US e8 gasket with my pump it is in different size slightly especially the right bottom part, but when i put US e8 gasket the right bottom side hole still not covered by pump, however using jdm e7 pump, it fits (covers) all area of the water pump like original 4g64 block one, is anybody tested this before? is JDM car has different water pump than US market 1? , thank you
Old Sep 24, 2008 | 08:38 AM
kdtm's Avatar
honestly i dont know, but i also have a jdm evo, so go for it and see if it works!! if so let me know...if it works i may be willing to try this conversion
Old Sep 24, 2008 | 09:52 AM
rawkus's Avatar
Here are a couple of picts of the water pump assembly from the European VII service manual, it should be exactly the same as the JDM VII.
http://i92.photobucket.com/albums/l1...o/Picture1.png
http://i92.photobucket.com/albums/l1...erPumpcopy.jpg
If someone can post the USDM Service manual and compare what the gaskets look like, we might be able to figure out if it will work or not.
Dan
Old Sep 28, 2008 | 08:13 AM
bab090's Avatar
can sonebody post US e8 water pump picture closely, i will post JDM e7 pump pic soon, so we can compare, actually i have ordered gasket from US for e8 and it was different for jdm e7,
Old Sep 28, 2008 | 08:21 AM
bab090's Avatar
ok i found US e8 pump pic, Thanks 9GUY9, what i am saying is this red area from pic, guys please tell me is this the problem area? with 4g64 and i will post jdm evo7 pump pic shortly so we can discuss, cheers
Attached Thumbnails 4g64 setup. JDM evo VII water pump, no adapter-us-water-pump.jpg
Old Sep 29, 2008 | 04:55 AM
Gary@MellonRacing's Avatar
u are talking about the alternator brace or braket right ????? apperently the evo 7 water pump does not have the same bolt pattern to carry that black brace if u have an evo 8 water pump u need to get an evo 8 alternator brace
Live4Redline
Mar 27, 2026 01:19 PM
evolve_VIII
444
Dec 16, 2020 08:11 PM
babaz7
Jun 10, 2017 09:58 PM
Jabu
Feb 7, 2012 02:02 PM
SeanC
Nov 27, 2007 03:21 PM
