TPS is at 98.823 under WOT???
Old Sep 28, 2008 | 12:51 PM
EvolNinja's Avatar
Ok, here's the scoop. during the removal of the broken BISS screw, I had to remove the TPS sensor so it don't get melt since I torch the crap out of that hole due to it wouldn't come out using bolt extractor. Anyway, I remember marking the sensor before removing both screws that holds the sensor, but that was after I remove both and now it's OFF. I did put it back as close to what I think it should be. Is that the cause of the TPS data being 98.823 during WOT??? If that is the case, to which direction should I adjust it back to stock? Clockwise or Counter? Thanks ahead for the help.
