boost flutter
Old Oct 2, 2008 | 07:19 PM
EatSleepBoost's Avatar
boost flutter
my boost gauge is moving rapidly within about 3psi when doing a pull at WOT. I understand i need to do a boost leak test which i will do tommorow.
my question is..
Can anything else cause a boost flutter??? (i.e. wastegate) my boost is ecu controled
Old Oct 2, 2008 | 07:25 PM
Jeff_Jeske's Avatar
Mine does the same thing at high boost but stays rock solid at 20psi. I've done boost leak tests and they are solid to 28psi. I too am using ECU based boost control with the GM3PORT. Car runs great just the boost gauge that acts retarded.
Old Oct 2, 2008 | 07:57 PM
interesting. thanks. any other inputs
Old Oct 2, 2008 | 07:58 PM
is it posible if i upgrade to the jdm map and gm boost control solenoid that it may solve an issue?
Old Oct 2, 2008 | 08:01 PM
Macaroni's Avatar
MBC FTW! My boost gauge holds solid at 23 lbs. all the way to redline
Old Oct 3, 2008 | 10:35 AM
srajeremy's Avatar
wastegate can cause it but that doesnt mean its bad also if you messed with anything or replaced any of the stock lines
Old Oct 3, 2008 | 10:52 AM
only line that was replace wat the one going to the wastegate with the boost pill which has been in there for a while. i will do a boost leak test this weekend and report back
