help please
Old Oct 11, 2008 | 06:22 PM
herwick evo's Avatar
help please
hi,trying to get my car back to stock from aem ems to stock maf and stock ecu,what do i need to do ?thanks you ...
Old Oct 14, 2008 | 04:25 PM
blackevolution8's Avatar
Is the MAF being used with the AEM or not? If it is, just plug the factory ecu back in. If it isnt you'll need to install the stock intake with the MAF. Plug in the ecu and plug the MAF. If everything else is stock you should be fine. If you have other modifications it may not run well until its reflashed.
Old Oct 20, 2008 | 08:13 PM
the maf sensor and the wire and the plug was gone.it was cut off when i had the ems put on,
Old Oct 21, 2008 | 03:56 AM
I take it you did speed density in which case youll also need the stock map sensor. Ask around and Im sure youll find people that have those parts for sale.
