Coolant Temps some what disturbing?
Old Oct 12, 2008 | 10:44 AM
BaLListic_EVO's Avatar
I recently attended my first road course event. My car at this event did get fairly warm but didnt ever overheat. As i would run 3-4 hot laps i would have to run a cool down lap. After this event my car now after starting it from cold the temp gets fairly high then suddenly drops off to the normal position. My first guess is that i have a malfuctioning themo-stat. Any suggestions idea's? Also what could i do to improve my cooling for a roadcourse? I assume an aluminum radiator and possibly a cooler thremo-stat?
Old Oct 12, 2008 | 11:31 AM
Billy@EnglishRacing's Avatar
When is the last time you changed your coolant? Have you made any changes to your car?
Old Oct 12, 2008 | 12:01 PM
last change of the coolant was probally 30k miles ago... nothing recent has been done to my car its all the same. My bet still is on the thermostat.... Ill probally go ahead and order one...
Old Oct 12, 2008 | 12:29 PM
RazorLab's Avatar
Sounds like it needs a flush, possible bubble in the system.
Old Oct 12, 2008 | 12:39 PM
perhaps ill try to flush and refil with water then if the problem is solved drain some out and refil with coolant.... Is it fairly normal for these cars to heat in a road course event? like i say this was my first one so....
