Convince Me: E85 or Meth?
Old Oct 13, 2008 | 11:21 AM
hokiruu's Avatar
Originally Posted by SpoolnupTuning
This is correct!! You do not have to have a back up plan with e85, only a cable for when you wont to switch back to 93!! The only thing you really need is injectors if you already have a walbro intank pump! I would recommend going big now, like 1000's or even 1200's. Just because any good tuner can make them idle and drive like stock!!! Also you wont need to worry about running out of fuel with the bigger injectors!
Not trying to nitpick, but you don't even need a laptop and cable! Switching from E85 to regular premium fuel tune can be done with a toggle switch of FMIC sprayer switch using Tephras patch!
Old Oct 13, 2008 | 11:23 AM
mdsevo06's Avatar
Originally Posted by Craig King
Wow... so 2 stations w/e85? That's a gamble I would NOT be willing to take. At least with Meth, it's easier to obtain and you're not limited to 2 stations, with 20 minutes between each one.
Even in a big city like San Diego, we only have two station at the moment. You get use to it and learn to plan around it. E85 is more consistent and reliable.
Old Oct 13, 2008 | 11:24 AM
hokiruu's Avatar
Originally Posted by evane
yeah but E85 i would be paying 2.39/gallon and 91 would be 3.00/gallon + methanol
just seems like meth will be more expensive
Don't forget that you will use about 30% more volume on E85 than regular gas. This is the only "downside," but at 2.39, I'd hardly call it that. One look at 91 octane prices in other parts of the country, and the cost of 100+ octane race gas should have you convinced that for your situation, there really isn't any reason to debate it anymore.
Old Oct 13, 2008 | 11:26 AM
evane's Avatar
one E85 station in the town i live in and 3 E85 stations in the town i work in....also the towns i plan on moving to have E85 stations and stations in surrounding towns....i mainly want the safest solution
Old Oct 13, 2008 | 11:32 AM
hokiruu's Avatar
Then forget about meth altogether, in case we didn't already convince you.
If you want to be uber-safe, always have a wideband in the car, and get a ethanol content display which reads the output from a GM fuel composition sensor so you can know the exact ethanol percentage in the E85 your are running. If you ever get a bad tank or they change the blend, you will know. that's not completely necessary, but it's the absolute safest route.
Old Oct 13, 2008 | 11:35 AM
chad99evo's Avatar
instead of waiting for a certain boost pressure to be reached before the meth (rest of your power)kicks in, its always there because its in the fuel. 29 psi at 3400 rpms or so and it almost like driving a non turbo motor its so torqy! i love it!
zeitronix zt2 with red led zt2 guage. $370 on ebay.
boost controller that can handle lots of boost, we were at 32 psi before we saw knock, but my AEM EBC only has a 2 bar psi onboard sensor(you must buy the 5 bar optional or some sh*t), so instead of risking breaking it, we went down to 29 psi to be safe
i only needed 880 cc injectors
Old Oct 13, 2008 | 11:42 AM
evane's Avatar
alright guys! i'm convinced! theres just some things i need to do before switching over....clutch is slipping so thats numero uno! then i'm going to do a 60k mile service with gates timing belt and balancer belt and brake pads...
Old Oct 13, 2008 | 11:47 AM
evane's Avatar
so chad99evo...your running 29 psi with 880cc injectors? whats your injector duty cycle look like?
Old Oct 13, 2008 | 12:00 PM
Spoolin18's Avatar
Are any of you guys switching over fuel lines, etc. before running this stuff? Or are you simply putting it in the tank and not worrying about it?
Old Oct 13, 2008 | 12:19 PM
SpoolnupTuning's Avatar
Not everyone wants to switch back and forth! Most of my guys always wont to keep the cars on e85 all the time! Which I cant blame them seeing it smells so good and makes so much more hp and tq than 93! plus you can find e85 in NC allot easier than other states.
Old Oct 13, 2008 | 12:42 PM
fugiwara's Avatar
wow, I learn so much about E85 reading from you, thanks so much.
Another thing is there are less parts to be added to the car, I personally like to keep everything clean and simple.
E85 hands down, no question. You'll notice a lot of people (including well established tuners) are ditching meth in favor of E85. In fact, E85 alone is producing massive gains over meth, often without even touching the tune. You can tune more aggressively, AND more reliably with it than meth. No finnicky failsafes with failsafes for the failsafes, which can still fail like with meth. Meth is a narrow margin of safety whereas E85's is huge. You can make more power with a very conservative E85 tune than an aggressive Meth tune.
I personally consider Meth to be like an outdated band-aid solution compared to running E85, and mostly just for people who either can't get ahold of E85 in their area, drive too much in areas without it, or whose racing class doesn't allow it.
It's the 105 octane "torque fuel" that cleans your engine and can result in up to 35% reduced tailpipe emissions, while not being middle-east oil dependent fuel to boot!
Old Oct 13, 2008 | 12:47 PM
evane's Avatar
+1 for clean and simple!
Old Oct 13, 2008 | 01:40 PM
tvor's Avatar
What about when the E85 mixture drops to more like E75 in the winter? I have heard some stories about bad batches of E85 or lower ethanol content depending on the time of year and where the fuel is coming from?
Old Oct 13, 2008 | 02:02 PM
KevinD's Avatar
95% IDC.
Old Oct 13, 2008 | 02:11 PM
sawgunner06's Avatar
well i am tuned for 93 octane and have 85 on post because I live near ft benning so as i read it seems that I cant just ride up to the gas staion and put 85 in and be fine with it right
guess i am asking for a yay or nay in this statement.
