Dont know what to do. Need Help!
Old Oct 13, 2008 | 02:33 PM
Dj M@nny's Avatar
hey wassup guys. I have a evo ix mr with hks rs intake, a tanabe concept g blue turboback and tune by big AL. the car felt crazy with just a few mods. Al did an amazing job. Recently I been thirsty for more power so I went an got a walbro 255 fuel pump, buschur's ported manifold & fabricated 02 housing, hks 272's cams and Ams intercooler+ lip sitting on my garage. I didnt buy the ams uip + small battery kit because i want to know if its worth the price? Will i be better off not getting it and install everything and tune or should i ad it to the list? Also im open for any other recomendations. thanks for your time
Old Oct 13, 2008 | 04:21 PM
Duh Panda's Avatar
why not add it to your list... you are already there..
anywho if you get a tune for it then lol it wont make that big of a difference
Old Oct 13, 2008 | 10:12 PM
speedypollard's Avatar
you will hate the small battery kit! just use an uicp that utilizes the stock battery
Old Oct 13, 2008 | 10:32 PM
phenaly's Avatar
Why would he hate the small battery kit?
The way I see it is run the small battery with shorter route piping.
Old Oct 14, 2008 | 03:54 PM
Dj M@nny's Avatar
what are the side effects from using the small battery kit? from what ive read in many threads is that the AMS & Buschurs uip is less restrictive and cuts off more than a foot in length. THe only thing i could find out is that in only increases throtle response and not much hp is gain.
Old Oct 14, 2008 | 03:58 PM
Dj M@nny's Avatar
is there really a difference in hp gain from a uicp/stock battery to a uicp/mini battery ? And also with all the bolt-ons i have should i also get some fuel injectors or just leave them for when i upgrade my turbo
Old Oct 14, 2008 | 04:02 PM
EvoFredo's Avatar
ive got a buschur uicp and mini battery kit . the space it opened up was great. looks are killer and shorter route to the tb is always a plus. by the way ive seen ams uicps and my bushur set up is way better. you could see where ams could have improved is a couple of bends. buschur ftw
Old Oct 14, 2008 | 04:10 PM
blackevolution8's Avatar
Im not sure if its worth that much money if youre not looking to push a lot of power and weight savings. Mini batter does save weight, uicp does free up a lot of bends and will increase some hp. The less restriction will probably be more beneficial to high hp builds. Although it does free up a lot of space and looks a lot nicer. I spent the money because of both reasons.
Old Oct 14, 2008 | 04:11 PM
4g63smokinall4s's Avatar
I have the ETS Short route UICP and Small bat Kitt.. just makes the engine bay look so much cleaner aswell as adding performance! I would def do it if i was u!
Old Oct 14, 2008 | 08:16 PM
Dj M@nny's Avatar
thanks guys. i appreciate the info. GOing to get that setup a soon as possible.
Old Oct 14, 2008 | 08:55 PM
eitan's Avatar
The only real concern I'd have with a small battery is if you run E85 or AEM EMS, you'd be stressing the battery getting the car to start.
Old Oct 15, 2008 | 07:09 AM
Dj M@nny's Avatar
well then i think ill be pretty fine. i think with the setup im trying to achieve i wouldnt need to run e85 or aem ems. thanks for the info
