Oil Report(Blackstone)&K&N Air Filter
Old Oct 15, 2008 | 05:41 AM
EvoWrxowner's Avatar
Received my report with the following negative:
"Silicon shot up to 52 ppm , and if this is from dirt getting past the air filter, it is making the oil abrasive. We suggest checking the air filtration system closely."
I am running an ETS kit( installed 2/08 brand new) with an RU-4260 K&N cone filter.
Oil was changed 12/07, just prior to air filter install.
I find it hard to believe the K&N is letting dirt through.
Anyone out there use Blackstone and had a similar report/problem?
Mods are in my signature.
Old Oct 15, 2008 | 05:42 AM
MR Turco's Avatar
it could be dirt getting by or the oil on the filament.
Old Oct 15, 2008 | 06:08 AM
Are you running a K&N?
Old Oct 15, 2008 | 06:17 AM
MR Turco's Avatar
no i run the blitz. I really hate running oiled filters.
Old Oct 15, 2008 | 09:47 AM
Can anybody help out here?
Old Oct 15, 2008 | 11:00 AM
Erik@MIL.SPEC's Avatar
My silicon content runs anywhere from 11ppm to 13ppm with an inexpensive paper filter. 50+ppm is way, way high.
Old Oct 15, 2008 | 11:04 AM
spdracerut's Avatar
It is very well documented that K&N filters allow significantly more particles to make it through the filter compared to a factory paper filter. Search on any of the diesel truck forums.
What do you expect though? The K&N makes more power by being less restrictive. Less restrictive means it's more porous and therefore not going to catch as much dirt.
IMO, if you don't plan on keeping the car for more than 200k miles, I wouldn't worry about it. Also, changing your oil often helps alleviate the issue.
Old Oct 15, 2008 | 12:14 PM
hokiruu's Avatar
No surprise here whatsoever. After my own experieinces and researching others' and some tests, I stopped using K&N and similar filters about 8 years ago.
Mr. Turco are you using the Blitz stainless or paper filter?
Old Oct 15, 2008 | 12:18 PM
MR Turco's Avatar
The blitz drop in. It is blue. I am pretty sure it is cotton. That is all i know
Old Oct 15, 2008 | 12:40 PM
Evolessfornow's Avatar
12/07 was the last time you changed your oil?
Old Oct 15, 2008 | 05:35 PM
20psiMR's Avatar
Jesus you havent changed your oil in 10 months? Umm ya that would be a problem. Its true oiled filters do let a bit more stuff through, thats why I still change my oil every couple thousand miles regardless of anyone saying they can go 10k per change. Come one, oil is cheap do you really want to stretch it out that long? Just asking for trouble if you ask me.
Old Oct 15, 2008 | 05:48 PM
lemmonhead's Avatar
absolutely nothing wrong running the K&N. Just make sure you oil it enough. Not enough oil and it will not collect particles. I think All that talk of more flow = less filtration is really not all that true.
Old Oct 15, 2008 | 05:53 PM
codean's Avatar
And too much oil will cause issues with the MAF...
Old Oct 15, 2008 | 07:33 PM
COL Knock's Avatar
ehhh, if you have less filtration just change the oil more (engine oil)
Old Oct 15, 2008 | 08:40 PM
shadow1's Avatar
Read about the experiment that K&N did on their website to debunk the MAF oil issue. They basically soaked a filter with oil and purposefully got oil on a MAFS. It did absolutely no damage.
