A little Help?
Old Oct 17, 2008 | 07:43 PM
MEVO1GT's Avatar
A little Help?
I am in the market in buying a Evo 9 MR but I am not sure what the compression should be on the motor with stock setup. I tried doing research on here but everything I found was either people saying there numbers were low or blown. Any help from you guys would greatly be appreciated as I would love to join your community!!!! Also I hope this is the right section for this question if not please mods move.
Old Oct 17, 2008 | 07:44 PM
MEVO1GT's Avatar
By the way this one evo I was looking into buying I got him to bring to a mechanic, his reply is as follows.
I called you to let you know about the result of the compression test and it
was 118,118,120,118 ( PSI ) according to the mechanic, the car was hot probabely
made the reading low, but I really don't know about the average for the Evo's
compression. All I can tell you is that the car is in mint condition.
Old Oct 17, 2008 | 07:45 PM
bluebanana23's Avatar
my 03 viii with 42K was 175 across
Old Oct 17, 2008 | 07:50 PM
ak47po's Avatar
Old Oct 17, 2008 | 08:04 PM
MEVO1GT's Avatar
so basically I should stay away from that car
Old Oct 17, 2008 | 08:22 PM
MEVO1GT's Avatar
So Do You Guys Think I Should Stay Away From A Car That Is Reading 120 All The Way Across
Old Oct 18, 2008 | 08:36 AM
VRSF Tiago's Avatar
Personally I don't think so.
One compression tester might be different from another and if you are getting the SAME compression across the board there is either something wrong with your gauge or the procedure.
The fact that there is no/very little variance between the numbers would lead me to believe the numbers are fine.
If you need reassurance, do a wet test where you put a tablespoon of oil into cylinder via the spark plug hole and then try the compression test. If the compression results rise it's the rings. That doesn't necessarily rule out any leaks in the head/head gasket but I think it's very unlikely one would have numbers so consistent across the board and have a problem.
Old Oct 18, 2008 | 10:44 AM
MEVO1GT's Avatar
Thanks For The Help
jungle_327
Midwest Region
Oct 6, 2014 07:23 PM
tundeclips
Jul 25, 2010 08:36 PM
hotshot1
Mitsubishi TC-SST Discussion
17
Apr 27, 2010 09:24 AM
Gracer26
West Region
Jan 4, 2010 12:46 PM
BOOMIX
Mid-Atlantic Region
Mar 1, 2007 11:12 AM
