need help asap!!!!
Old Oct 18, 2008 | 04:48 PM
E VOL IX's Avatar
need help asap!!!!
doing a clutch install for a customer on a IX MR (6spd)... this is my first 6 spd. the clutch is a quartermaster twin... it came with a realease bearing with 3 bolt holes to bolt in (like a 5spd) well i didnt know the 6spd didnt have bolt holes until just now... amd i screwed or what??
Old Oct 18, 2008 | 05:14 PM
E VOL IX's Avatar
anybody???
Old Oct 18, 2008 | 05:42 PM
Scottr126's Avatar
Yes... wont work.
Sorry.
Old Oct 18, 2008 | 06:03 PM
Koroshiya's Avatar
Originally Posted by Scott@AMS
Yes... wont work.
Sorry.
So what do you do.. Devo sells a "conversion kit" that appears to just be an aluminum sleeve. Will that work or does he need to put back in the stock and find another clutch?
Old Oct 18, 2008 | 06:05 PM
E VOL IX's Avatar
?? the sleeve does seem to be the conversion... problem is if i put this sleeve on the input shaft then the bearing over top of it.. it is NEEVVVEERR coming off..
Old Oct 18, 2008 | 06:19 PM
psphinx81's Avatar
it comes off, when i was installing the same exact clutch on the same tranny that sleeve just has to be dead centered and it slides fairly easy. i posted in the 2 other threads on how to get it to work. hope it helps
