STM's Ricer goes on a diet...
Old Oct 29, 2008 | 04:03 PM
  #46
EmeryatSTM's Avatar
Originally Posted by steelcityevo8
Dont want to go off topic! But did I miss this machine having a motor failure. I know that it was stock motor. I dont recall hearing about a failure???
That sure looks llike a hole in the block behind that there band-aid hhaaha
Yes the car let go finally. It took ALOT of abuse but finally let go with a 9k miss shift. Here is a video
http://videos.streetfire.net/video/S...CER_187598.htm
-Emery
Old Oct 29, 2008 | 04:17 PM
  #47
steelcityevo8's Avatar
-Emery
Oh I feel ya man . I put a rod thru mine as well. sucks for sure. Looked like the whole big half of the rod layin on the track??? Is that what I seen???
Old Oct 29, 2008 | 04:36 PM
  #48
EmeryatSTM's Avatar
The rod came out in three different spots in three peices lol. No big deal though, We went 10.0 and trapped 142 with the stock motor.
-Em
Old Oct 29, 2008 | 04:39 PM
  #49
justboosted02's Avatar
nice work
Old Oct 30, 2008 | 03:09 PM
  #50
blueG60rado's Avatar
I love lightened evos. That **** is sick.
Old Oct 31, 2008 | 09:47 AM
  #51
EmeryatSTM's Avatar
A little more work has been done. We have now deleted the ABS. While doing this we put together a kit.
In the images above and below you can see all the mess that is deleted with this kit.
These can be found here... http://www.streettunedmotorsports.co...emoval_kit.htm
-Emery
Old Oct 31, 2008 | 09:54 AM
  #52
Mellon Racing's Avatar
man that looks good Emery, nice friggin work!
Old Oct 31, 2008 | 09:59 AM
  #53
scorke's Avatar
Originally Posted by davidbuschur
Have you considered just using the factory aluminum roof on the car? If I had the ***** to take my steel roof off my RS that's what I'd do.
I'm sure he has, but unlike you he doesnt mind using AMS products
Scorke
Old Oct 31, 2008 | 10:08 AM
  #54
DaveK's Avatar
Just curious if you have a workaround for those who want to lose the ABS, but need all the wiring to work with the traction control (ACD) system?
In my car I removed the factory booster & master cyl, installed a Wilwood dual master setup, and re-ran the brake lines, much like your new kit offers. I pulled 1/2 of the ABS brain out (side that had the brakes lines going in), but had to leave the plastic box where all the wheel speed sensors connect in. Just curious if there's an easy way to bypass that box?
Dave
Old Oct 31, 2008 | 10:14 AM
  #55
EmeryatSTM's Avatar
Dave
Not that I know of yet. I am taking all the wiring out and not using the ACD anymore so I probably wont find out.
-Emery
Old Nov 3, 2008 | 01:06 PM
  #56
4g63girl's Avatar
Still yanking out weight! Now we have Bushcur's Moustache Bar and Rear Diff Mounts
The Moustache Bar:
Old & Rusty: 15.9 pounds
New & Shiny: 3.2 pounds. Awesome.
Mounts:
Old & Rusty Pair: 7.65
New & Shiny Pair: 4.25
There's a bit over 16 pounds off the rear end... wish your girl could say that?! buahahahaha
-Shawna
Old Nov 3, 2008 | 01:45 PM
  #57
03whitegsr's Avatar
FWIW, stripping the car out definitely affects the "driveability." You pull out all the sound deadening, extra brackets holding the dash in, etc. it makes the car a rattle trap.
It makes a very noticeable difference in performance though. I pulled 450 pounds out of my old 2G AWD back in like 2002. I was taking down 50-trim/60-1 setups with a little T28 that I auto-X'd the hell out of and drove 40+ miles a day to work without a heater in below freezing weather.
It was a complete rattle trap turd, but man was it fun to drive.
Old Nov 3, 2008 | 01:46 PM
  #58
scorke's Avatar
-Shawna
If your shaving more than a few grams of anything off of a girls rear end you got issues
Scorke
Old Nov 3, 2008 | 05:25 PM
  #59
StreetThisEvo's Avatar
Nice work on the ABS delete kit! I'll consider doing this along with the removing my ACD system.
Old Nov 3, 2008 | 06:03 PM
  #60
03whitegsr's Avatar
Originally Posted by Jrod@Buschur
Originally Posted by Buschur Racing Weight reduction page
Installation of Buschur Racing 3" Turboback Exhaust: 37 lbs. The stock exhaust weighs 60 lbs, the BR exhaust weighs in at 23 pounds.
Is the BR turboback made from 18 gauge material? Seems a little too light for 16 gauge material.
