Will Evo IX 6 speed trans. fit in Evo VIII?
Old Oct 22, 2008 | 01:01 PM
zb03ozrally's Avatar
I'm posting this question for a friend. He's got 2004 Evo VIII with 5 speed which is blown. He found cheap 6 speed out of Evo IX. Will it fit? Thanks.
Old Oct 22, 2008 | 01:42 PM
WickedIXMR's Avatar
First of all thats really stupid to do because the 6 speed transmission is alot weaker then the 5 speed. Plus it wont be a direct swap, you will need a conversion kit which would probably run roughly around 400 dollars. Just tell your friend to take his 5 speed out and send it to shepard racing to get it built.
Old Oct 22, 2008 | 09:32 PM
94AWDcoupe's Avatar
yes it fits. you will need the trans mount, wire harness (clip for reverse is different so it will need to be spliced in) and shifter cable assembly.
Old Oct 22, 2008 | 09:39 PM
Skywarp's Avatar
It fits. Shifter, Shifter cables, trans, and console. speed sensor should be the same. If you race your car on the track a lot, the 6 speed might not be for you. Quite a few threads on its durability. For a mildly modded, DD evo, its not bad. Theres a conversion kit for the swap, WickedIXMR?
evo8vz
Oct 16, 2016 05:18 PM
M1 Autosport
Mar 22, 2010 03:26 PM
M1 Autosport
Mar 22, 2010 09:39 AM
shvc1991
Dec 16, 2006 10:46 PM
Evolution2003
12
Nov 6, 2006 12:15 AM
