Cyclinder Misfire. Help
Old Nov 22, 2008 | 01:37 PM
evolution2186's Avatar
Does it idle odd after the engine is warm? Also are you running pump gas or ethanol?
Old May 16, 2010 | 04:37 PM
Evojj25's Avatar
when it comes down to the misfire in cyclinders, what could be the main problem of it? bc im having a misfire in my cyclinders.
Old May 17, 2010 | 05:40 AM
gsrboi80's Avatar
Try to determine whether or not the code triggers at idle or cruise
-Ignition system not up to snuff (Plugs, wires, coils,etc...)
-Too much idle timing
-large gaps in between cells in timing and fuel maps
-drivetrain harmonics being picked and fed to the ECU (Mitsubishi's answer) to the 03-04 P0300. Their are to rom updates to try and fix it
-Issues with head components
-Some Cams have been know to be not so friendly over the years
Just some things to look at. If everything checks out I'd disable the damn thing in the rom and be done with it
Old May 17, 2010 | 11:46 AM
barneyb's Avatar
Uhh, you could go back and read post #3 again. You question has been answered.
Old May 17, 2010 | 11:59 AM
CoachG's Avatar
The plug wires have been a weak link. If you are convinced that the ignitio system is to blame and you've already done the plugs...try the wires.
Good luck.
Old May 17, 2010 | 12:14 PM
bman4123's Avatar
I have the same problem with my kelford 272 there's nothing really that can be done form what i have been told due to the cams
Enjoi926
May 31, 2017 06:47 PM
Chokkan
23
Jan 9, 2017 09:45 AM
Ian0611
50
Jul 6, 2016 11:50 PM
dillons13
Sep 2, 2015 06:25 AM
dustin57
25
Nov 30, 2012 03:20 PM
