Boost creep help
Old Oct 29, 2008 | 10:54 AM
keevo54's Avatar
Originally Posted by razorlab
Rod adjustment is not going to do anything if the exhaust gases can't flow well enough through the small 02 housing WG opening. You could drive around all day with the WG 100% open and still have the issue.
We've seen half a dozen megan/ebay 02 housings cause creep, the solid fix was always a better 02 housing or seeing if the WG hole can be ported enough without compromising the unit...
Yea I was thinking that but was really hoping the rod adjustment would help a lil
Old Oct 29, 2008 | 01:01 PM
sparky's Avatar
Rod adjustment is not going to do anything if the exhaust gases can't flow well enough through the small 02 housing WG opening..... We've seen half a dozen megan/ebay 02 housings cause creep, the solid fix was always a better 02 housing or seeing if the WG hole can be ported...
^^ten-four^^
Old Oct 29, 2008 | 01:44 PM
keevo54's Avatar
Thanks for everyones help. I will be pulling it off during Thanksgiving. I e-mailed megan to see about warranty but if not does anyone have advice on exactly what/ how much to port.
I do not have a grinder only an electric drill
Old Oct 29, 2008 | 02:27 PM
sparky's Avatar
There is a thread about porting the O2 Hsgs. Maybe someone will post the link. Otherwise, I kind of recall something about grinding the existing hole out to about the diameter of a golf ball.
Old Oct 29, 2008 | 02:29 PM
keevo54's Avatar
Thanks for all the advice sparky
I will search for it tonight
Old Oct 29, 2008 | 02:30 PM
sparky's Avatar
You may be able to do it with the proper grinding bits for your drill. I did some of the porting on my turbine housing with my 18 volt portable drill.
Old Oct 29, 2008 | 06:24 PM
keevo54's Avatar
Lol I talked to Megan Racing and they told me there was no way there o2 housing was the cause. They said I needed an electric boost controller and that it was creeping because I had the resonated test pipe.
Time to start porting
Old Oct 29, 2008 | 06:28 PM
whoang40's Avatar
I like how Megan Racing is avoiding the issue by blaming another part. An electronic boost control will work, but that's just a bandaid. Port the **** then lets see some boost graph comparisons.
Old Oct 29, 2008 | 06:30 PM
90GSXDan's Avatar
LOL. Megan's product is a cheap chinese paperweight. I have it but I ported mine and it works great! Should come like that from there "factories" lol
Dan
Old Nov 24, 2008 | 06:39 AM
keevo54's Avatar
I think I am going to put on the stock o2 housing until I buy an o2 dump. The stock housing will fix the boost creep, correct?
Old Nov 24, 2008 | 07:55 AM
andrewzaragoza's Avatar
you could just buy a dremel tool for around $30-40 and just make the hole a bit bigger. that way you do not need to put the stock o2 housing back or get a new o2 housing.
Old Nov 24, 2008 | 09:10 AM
C6C6CH3vo's Avatar
Boost creep is when the WG opens due to pressure on the turbine as it looses efficiency with increasing pumping rates (higher rpm). Boost will drop. You can tighten the WGA to hold it more but it will spike at lower RPM and engine probably won't be happy at all near redline. Thats boost creep. You have spiking, the boost control system probably needs an overhaul or cleaner configuration
Old Nov 24, 2008 | 09:55 AM
vvhiteix's Avatar
i have one off my car thats ported alreadyyy....let me know if you want it. adjusting stuff isnt gonna help the problem is the hole... the exhaust cant get out fast enough... plain and simple.
Old Nov 24, 2008 | 11:18 AM
Ruff Ryda's Avatar
^^ Is this right?
Old Nov 24, 2008 | 11:42 AM
sparky's Avatar
No, that is not right. It`s wrong.
