TPS issue, possibly weather/temp related?
Old Oct 29, 2008 | 02:50 PM
mcwop23's Avatar
My car threw a P0121 code last week and was idling around 2800 rpms. I checked all the connections and cleared the code and the next day everything seemed fine. Later on that night it did it again although it didn't throw a code. Now it seems like it will idle perfectly in the daytime when it's 60-70 degrees and idles super high when it's 30-50 degrees at night. I just want to make sure it isn't a small issue before I think about replacing the sensor. We already made sure all the vac lines were hooked up proper, especially the ones to the intake manifold.
Old Oct 29, 2008 | 04:28 PM
1d10t's Avatar
Could be an idle control valve. You can test the tps sensor
Old Oct 29, 2008 | 05:16 PM
Aman's Avatar
do a sweep on the tps that will tell u if ur tps is good or not.
Old Oct 30, 2008 | 07:58 AM
mcwop23's Avatar
thanks for the replies guys, i'll check it all out today
kaj
16
Jul 2, 2014 12:39 PM
4DOORGALLOR
Mar 11, 2010 02:16 PM
slvevo8
23
Dec 23, 2009 08:34 PM
SmurfZilla
E85 / Ethanol
Oct 26, 2009 05:35 PM
Fitz
Sep 10, 2007 09:00 AM
