What should I do next?
Old Nov 10, 2008 | 07:02 PM
AndreisBoy's Avatar
I have an 05' Evo RS, that I put exhaust, intake, a Fidanza clutch, and flywheel into.
Everything else on it is stock. I would like to put a bigger turbo on to get me around 400+ AWHP and still to be a daily driver.
Any advice on what to add on next?
I'm new at this.
I don't want to run meth injection though.
What else would I need to buy?
Thanks,
Dustin
Old Nov 10, 2008 | 07:21 PM
sparky's Avatar
You're gonna get told to search. There are four very good bolt on turbo choices that'll get you close to your target power level, depending on what octane gas you'll be running. These four are the 1)Forced Performance(FP) Green, 2) FP White, 3) FP Red, and 4) the CBRD BBK(2 variants).
You'll need a higher volume fuel pump, a set of upgrade camshafts, higher flow injectors, and a larger front mount intercooler, as well as an ECU tune, among other things. Also, you may want to consider E85 as an alternative, high octane fuel.
Old Nov 11, 2008 | 02:33 AM
1NastyMR's Avatar
cams w/ ARP headstuds, injectors, fuel rail, Fuel pump, intercooler upper/ lower pipe, intercooler, 35R, Twin disk clutch. Pick from those mods ur gonna need all of them eventually
