Help Melted Spark Plugs
Old Nov 11, 2008 | 11:20 AM
cosworthevo1133's Avatar
hey i guys i have a hue ignition problem and need all the help and opinions i can get. i have an AEM EMS, and a fully built Cossie head, with many other supporting mods. when we retuned my car we noticed that the spark plugs were bad so we replaced them with a step colder. later that night i was in fourth gear and it started misfiring badly. i took my car immediately in and the spark plugs were so hot it took us an hour to get them out so we wouldnt ruin the threads. heres the bad thing, 2 of the four tips were melted because it got so hot, we regapped them to 20 and went a step colder, i changed my boost from 25psi to 18psi and staying out of fourth gear on open throttle. what do u think could be causing the problem? Coil packs? spark plugs? relay wires? cold starter? alternator?
Old Nov 11, 2008 | 11:26 AM
derekste's Avatar
who tuned the car, and more importantly, how do you know it was tuned properly?
Vivid Racing's Avatar
Sounds like it was running to lean. Check the wideband make sure the sensor is good.
Evan Smith
Old Nov 11, 2008 | 11:42 AM
ok thanks... keep giving me input guys
Old Nov 11, 2008 | 12:40 PM
come on some one has to atleast know something about this problem
Old Nov 11, 2008 | 12:48 PM
gsrboi80's Avatar
CC temps were through the roof likely. Sounds like the tune to me. Running it way lean.
Old Nov 11, 2008 | 01:22 PM
RoadSpike's Avatar
Why don't you post a picture of a melted plug.
Lets see if its has classic over heating signs like a blistered insulator.
Old Nov 11, 2008 | 01:43 PM
linwoodm's Avatar
Probably running lean
Old Nov 11, 2008 | 01:46 PM
Johnboy1065's Avatar
Prolly running lean,
check the injector clips to make sure it's getting a good connection. other than that it is probably the tune.
Old Nov 11, 2008 | 02:46 PM
oneofakindtrini's Avatar
LLLLLLLLLLeaNNNNNNNNNNNN
Old Nov 11, 2008 | 08:24 PM
just retuned the car and its not running lean but still wondering if my coil packs are going bad? the car has 35k on it, i kno they are suppose to last till about 80k but im just wondering if the coil packs are going out, i have am ignition problem for sure we just cant find the source.. i havent gotten on it in fourth now to paranoid to melt them again.. what is a good suggestion?
Old Nov 11, 2008 | 09:42 PM
RoadSpike's Avatar
you going to post a picture of a plug or not?
Its a lot easier to diagnose problems when you can see damage
Old Nov 12, 2008 | 05:56 AM
rgeier11's Avatar
Melted plugs are almost always because of a burned valve.
Old Sep 2, 2010 | 05:41 PM
montanaevo's Avatar
had a similar thing happen 4 days ago only WOT in 5th gear at like 140mph. Each plug had some damage but 1 worse than the others. Didnt have any symptoms till after i backed it back down tho. I have 2k on a forged bottom end and some decent bolt-ons. I also am running a AEM tuned at Carz performance in Denver. My air/fuel showed it was in a good range the whole pull so I'm wondering if its timing? For now I replaced the plugs 1 step colder and I'm sending my stock ECU to WORKS perf in california to have a flash done on it and mayb just run that.
Old Sep 2, 2010 | 06:07 PM
evo224's Avatar
shes leannn
i bet its your tune. i have a pretty much stock car just fp red stock head with 272 cams etc basics. the guy tuning the car put the wrong plugs in by accident and fried all 4 plugs. you gotta watch bc my ignition system couldnt handle it and the bottem end went kadoom! so def get your tune checked bro best of luck
