HG swap questions: block clean? CAS orientation?
Old Nov 15, 2008 | 03:31 PM
scheides's Avatar
EvoM Moderator
Question #1: How clean does the surface of the block need to be? Am I close? There are a few spots that do still need some work, but the spots that still look like they have a bit of gasket material left on them are super smooth, can't even catch an edge with my fingernail.
Comments welcome please!
Question #2: what is the proper orientation of the cas? The cam pin is straight up, does the small side need to be up or down?
Thanks in advance!
Old Nov 15, 2008 | 04:47 PM
1d10t's Avatar
Remove all residue, then check for straightness. A good finish is RA50 for a new HG.
RA 50 is a measurement of texture that is good for sealing.
Old Nov 15, 2008 | 05:54 PM
Kracka's Avatar
How does one determine RA50?
Old Nov 15, 2008 | 06:00 PM
streetvision's Avatar
http://www.youtube.com/watch?v=O42b4...eature=related
has some good info
Old Nov 15, 2008 | 09:31 PM
scheides's Avatar
EvoM Moderator
I'm thinking of getting some 90* spinny 3M pads to finish the cleaning. I'm just out of juice with the finger scrubbing at this point.
Also, found on evomoto:
Originally Posted by evomoto
With the CAS housing installed and the cam bearing caps torqued down, reinstall the CAS trigger. Remember, the larger trigger vane will be in the first fully seated (in the slit) position to the right of the dowel pin when looking at the cam angle sensor side. Torque the trigger bolt to 16 ft-lbs while holding the cam with a wrench.
When installed properly and with everything in time (we're not at there yet in this install), the larger trigger vane should point down/right at about a 45° angle as shown in the picture. You may wish to leave the CAS cover off until the cam install is completed to verify its position when everything is set in time, as we have done for this picture.
http://evomoto.com/tech_info.php?tPa...70bbff080a07d8
Step #31
Old Nov 16, 2008 | 10:26 AM
scheides's Avatar
EvoM Moderator
bumpski
Old Nov 16, 2008 | 11:50 AM
RedLanEVO's Avatar
Wait...so what are you doing to your engine? What's HG?
Old Nov 16, 2008 | 03:14 PM
1d10t's Avatar
Call Jackson auto machine, ask what grit they use on the deck, as well as the method the use
Old Nov 16, 2008 | 06:42 PM
Kracka's Avatar
We got it back together and it runs!
Old Nov 16, 2008 | 08:25 PM
scheides's Avatar
EvoM Moderator
Headgasket....
Kracka
622
May 28, 2020 07:06 AM
scheides
95
May 21, 2016 01:38 PM
scheides
For Sale - Cars For Sale
12
Sep 9, 2015 08:37 AM
scheides
May 25, 2015 06:31 PM
Jakeg97
Jan 22, 2009 07:43 PM
