FMIC thickness?
Old Nov 19, 2008 | 10:42 PM
  #31
importjake00's Avatar
Originally Posted by TheDream
what's everyone's beef with Buschur? They've always helped me when I needed it. I would definitely go with ETS or Buschur.
BTW, Jake my intake is holding up real nice THX!
Did I sale you an Intake?
Sorry for the bad memory. I am glad its holding up well! I am thinking of switching over to the Perrin one myself.
And no beef, just giving my personal preference.
Old Nov 19, 2008 | 11:04 PM
  #32
john.schuber's Avatar
is a four inch overkill with fp red +meth or fp red+e85?
Old Nov 20, 2008 | 05:29 AM
  #33
SloRice's Avatar
4" isn't overkill for the stock turbo and definately isn't overkill for the FP Red.
Old Nov 20, 2008 | 06:27 AM
  #34
2highpsi's Avatar
It's not overkill for a Red at all. I run 30 psi on pump with my Red. If I didn't have a BR Race core I am sure my intake temps would be higher resulting in less power.
Old Nov 20, 2008 | 08:41 AM
  #35
sparky's Avatar
Are you measuring IT´s? If so, how high do they get with the Red and the BR Race FMIC at 30#?
Old Nov 20, 2008 | 08:56 AM
  #36
sparky's Avatar
Originally Posted by jouniu
How about increasing FMIC height & width to maximum you can fit? That makes more area to get cold air. Thinner is does not heat soak so easily. ....You cannot say 3.5" is always better than 3", there is many other things that have to think.
You´ve made an interesting point, jouniu. The frontal area of the FMIC core isn´t being taken into consideration in this discussion. Given two FMIC cores with equal internal capacity, which would do a better job of cooling the intake charge, a thicker core with a smaller frontal area or a thinner core that is both taller and wider than the first? Or, would there be no measurable difference in cooling capability between the two configurations?
Old Nov 20, 2008 | 09:48 AM
  #37
2highpsi's Avatar
I didn't tune the car, David did. He does log the AITs.
Answer me this... What produces a hotter charge (pre intercooler):
A. a stock frame turbo pushing 30 psi
or
B. a GT35R pushing 30 psi
Old Nov 20, 2008 | 09:54 AM
  #38
scorke's Avatar
A stock frame turbo pushing 30 psi.
A stock frame turbo that isn't a red is far past its real efficiency, if you are using a stokc turbo at 30PSI you should have a bigger turbo.
A Green blowing 30 PSI probably produces twice the IAT's a 40R would at 20 psi.
However there is a difference between a what requirements a green and a 40R has due to the amount of air they will flow, with a smaller turbo you don't want to be filling such a huge volume for lots of reasons not related to cooling, but related to engine response characteristics.
Scorke
Old Nov 20, 2008 | 09:58 AM
  #39
jouniu's Avatar
or
That is not the point. With stock you could produce hotter air but with bigger turbo there is much more air to cool down. If your stock put 38lbs air flow and 35R 60lbs, it is very easy to guess which one have more heat. It is not difficult to calculate heat energy in those two cases.
Old Nov 20, 2008 | 10:02 AM
  #40
2highpsi's Avatar
I asked because people question whether or not you need the best most efficient intercooler if you are "just running a red".
My point is this:
If you do not plan on running higher boost DO NOT BUY A RED. A stock 9 turbo will perform just as well as a Red with better spool up at low boost. The Red shines at high boost. So now we have established if you have a Red, you are running higher boost. Now we know that the Red at higher boost creates more heat than a larger (35r variant) turbo at the same level. Higher temps induce detonation requiring a drop in timing and lowering of power. So not only is it "okay" to run the better intercooler on a Red, it is probably even more so required to keep the AIT temps lower.
As much as I don't see eye to eye with you and believe that you will still argue the fact, I still believe that you are intelligent enough to know that is true.
Old Nov 20, 2008 | 11:07 AM
  #41
Lumpskie's Avatar
Originally Posted by SloRice
Thanks for checking my math Douscke. You were right, I mixed up lb/min and CFM. I meant to say it can flow about 40lb/min. At standard atmospheric conditions, that equates out to about 534 cubic feet per minute of air flow.
OK, more voodoo math that you don't understand and the numbers get BETTER!!
We are now down to 0.05 seconds (yes, 0.05) to fill the additional volume of the intercooler. I thought 0.6 seconds was way high but didn't have time at work to really confirm my answer.
If you're not a douche bag and would like to know what the voodoo math is, PM me and I'll tell you along with citing resources.
Your numbers are calculated based upon the output of a stock turbo at full boost, am I correct? If so, your numbers don't take into account the time for the turbo to actually reach that boost... which would relate back to the intercooler volume. It seems to me that the math would have to be derivative in nature. Maybe you already did that, but it's a question worth asking.
Old Nov 20, 2008 | 11:52 AM
  #42
stikiller451's Avatar
Originally Posted by dbsears
I say buy whichever one you get the best deal on. AMS, ETS, Buschur ones are all good and 3in or 3.5in will be fine (I would buy the 3.5in being more future proof) You will NOT notice the difference from 3in or 3.5in spool wise. Anyone that tells you otherwise is full of bs. Buy what you like or find the best deal on...
yes
Old Nov 20, 2008 | 12:53 PM
  #43
Dr. SS's Avatar
i switched from a 3" to a 3.5" and noticed no difference in spool.
Old Nov 20, 2008 | 01:07 PM
  #44
Lumpskie's Avatar
As curious as I am on finding actual data on the subject, I think you and the general concensus is right.
1091x
Jan 8, 2016 02:18 PM
Evolution Z
Aug 1, 2013 09:23 AM
foxbear2277
Jul 5, 2012 02:56 PM
Pizzamangtr
14
Feb 8, 2010 07:18 PM
EriCS
75
Dec 12, 2009 07:24 AM
