FP Red w/ Stock Wastegate
Old Nov 25, 2008 | 02:51 AM
sokaroza's Avatar
is anyone running a FP Red with a stock wastegate? ive heard people using one with there Greens but how about Reds?
Old Nov 25, 2008 | 03:08 AM
mr-derer2's Avatar
The turbo comes with a high pressure wastegate. Why run the stock one?
Old Nov 25, 2008 | 03:11 AM
sokaroza's Avatar
i sent in a ix turbo and had it upgraded and it didnt come back with the upgraded wastegate. i thought it would have.
Old Nov 25, 2008 | 04:46 AM
DimitrisIX's Avatar
it depends on the boost you want to get out of it.
Old Nov 25, 2008 | 05:33 AM
sokaroza's Avatar
lets say daily driver and between 27-29lbs.
Old Nov 25, 2008 | 05:46 AM
brodienuchies's Avatar
Then you need to upgrade your WG. Stocker doesn't hold boost that well on the stock turbo. I think FP has a descent range of WG's to choose from...just give them a call.
Old Nov 25, 2008 | 06:01 AM
sokaroza's Avatar
I will today. also my stock turbo hits 27 lbs right now and drops to 24 lbs close to redline. I am running e85 and meth on my stock turbo. I am just wanting to put the turbo on really bad and not wanting to have to do it twice incase the stock wastegate doesn't hold 27 lbs on the red for some reason.
Old Feb 18, 2010 | 07:33 PM
Carloverx's Avatar
bump.
I'm currently running a FP red with a stock wastegate. Could this be causing a boost leak (i.e. the wg isn't strong enough)??
I'm hitting 33psi but not making proper power so does this sound like the case?
Old Feb 19, 2010 | 04:05 AM
sparky's Avatar
.....I am just wanting to put the turbo on really bad and not wanting to have to do it twice incase the stock wastegate doesn't hold 27 lbs on the red for some reason.
To swap WGA's you do not need to R&R the turbo. WGA's can be removed and/or installed with the turbo mounted and a stock thickness radiator in place.
Old Feb 19, 2010 | 08:13 AM
tvor's Avatar
Originally Posted by sparky
To swap WGA's you do not need to R&R the turbo. WGA's can be removed and/or insatalled with the turbo mounted and a stock thickness radiator in place.
It's justa PITA
Be careful of knicking your rad when you do, but I've done that a few times now.
Old Feb 19, 2010 | 08:51 AM
churchja's Avatar
I have a stock WGA from a 2006 Evo IX MR and a FP 18 psi WGA if you're looking for one.
https://www.evolutionm.net/forums/6019422-post3.html
Thanks,
Jay
Old Feb 19, 2010 | 09:34 AM
scheides's Avatar
EvoM Moderator
What does your boost curve look like? i.e. how much boost are you holding at 6500rpms or so with a 33psi spike?
I'd try ecu-controlled boost before an uprated WGA.
Old Feb 19, 2010 | 09:41 AM
Silk's Avatar
My FP Red was shipped without a wastegate actuator for some reason so I ended up modifying my stock 8 one to fit. The most I could get out of it with just pulling the line off was 33 dropping to 30 by 7800 or so.
Old Feb 19, 2010 | 10:58 AM
Carloverx's Avatar
Thanks,
Jay
Hey, did they come with a higher rating than 18psi? Or are all the units the same and just adjustable?
It is this exact unit: http://store.forcedperformance.net/PROD/WAEVO18psi.html ? How many miles are on it? Very interested
What will an FP 18 psi wastegate hold up to?
Old Feb 19, 2010 | 11:05 AM
pls1968's Avatar
They also come in 25psi.
