Car Idles then dies
Old Nov 28, 2008 | 02:46 PM
The_Shocker's Avatar
Ranger's Robin
Thumbs down Car Idles then dies
I've searched for about 30 minutes, tinkered with my car and I can't figure it out...
Car starts, idles to about 1600, then dies... I can kind of keep it running with my foot on the gas, but only for about 10-15 seconds.
Car idles fine if I unplug the MAF sensor.
I all I did was go back and take the stock stuff off and replaced it with my ETS intercooler and pipes, and put my Megan Downpipe and Jun BL exhaust back on.
any ideas? This is pretty frustrating.
Thanks in advance.
Edit - I also unhooked the stock boost solenoid and put the AEM Tru Boost back on.
Old Nov 28, 2008 | 02:55 PM
Ranger's Robin
Just brainstorming, but does anyone think I could have not had the DP aligned right when I bolted it up to the turbo?
Old Nov 28, 2008 | 03:00 PM
wevo1985's Avatar
sounds like you missed a cuppler. you have a leak someplace after the mas.
Old Nov 28, 2008 | 03:01 PM
oneonlywgs's Avatar
It's probably throwing a code since you disconnected the maf. Check for other obd codes. You might have to adjust the idle screw. Did you check for boost leaks, when you changed the fmic? There could be numerous things of why its not running. I would go back on everything I changed and make sure they are connected correctly.
Old Nov 28, 2008 | 03:02 PM
Ranger's Robin
I double checked all of the couplers, but I may have to just check them again.
I reset the ECU after taking the sensor off, only reason I took it off was out of curiosity.
Old Nov 28, 2008 | 03:04 PM
Ph3n1x's Avatar
Keep the stock BOOST Solenoid plugged in.
If your idles with the MAF unplugged then possible a bad MAF Sensor.
Also can be a bad Throttle Body, TPS sensor.
Old Nov 28, 2008 | 03:05 PM
Ranger's Robin
Why would it just quit though, I literally drove it 10 hours ago
Old Nov 28, 2008 | 03:07 PM
Ph3n1x's Avatar
Who knows. I had a friend who had a similar problem. Car wouldn't idle for nothing. If he reset the battery the car would work for a little then go back to the same scenario.
Just a thought.
Old Nov 28, 2008 | 03:10 PM
burninrubb24's Avatar
stuff like that happenes all the time
Old Nov 28, 2008 | 03:11 PM
Ranger's Robin
Well when I reset it it didn't help at all.
I will have to go back through the couplers tomorrow, any other ideas would help a lot guys
thanks
Old Nov 28, 2008 | 03:12 PM
Ph3n1x's Avatar
thanks
Have you thrown any codes or tried driving to see if it throws any codes?
We can rule out bad MAF or you have have thrown a code.
Old Nov 28, 2008 | 03:14 PM
Ranger's Robin
I can't even get it running to drive
Old Nov 28, 2008 | 03:15 PM
Ph3n1x's Avatar
Check the IC pipes again make sure there connected and Tight. Make sure the Intake is on the Turbo and not slipped off.
Old Nov 28, 2008 | 03:17 PM
Ranger's Robin
*******it, I knew I should have made sure it ran before I put the bumper back on... first time I didn't.
Old Nov 28, 2008 | 03:18 PM
Ph3n1x's Avatar
lulz
