Biggest Cams...?
Old Nov 28, 2008 | 06:18 PM
1000AWHP's Avatar
Biggest Cams...?
Hello! I was doing some searching to find the "biggest" cams for an Evo VIII... It seems like either Jun or Tomei are the biggest. Have you guys found anything bigger? Something like where the 260s are bigger than others 280s? Or what about the "smallest" cams...? Does anyone know who makes the smallest cams? Like I can use 280s w/o having to use springs/retainers they r so small...? Thanks for all of your help/info!!!
Old Nov 28, 2008 | 06:24 PM
AWD Motorsports's Avatar
The duration does not tell the tale of which cam is bigger or smaller and which requires springs and retainers.. you need to look at the lift.. Some 280's have less lift than other 272's.. Kelford makes a 290 cam also.. you need to decide what you are going to do with the car and how much HP you want to make and then i could maybe give you a better idea of what cam to go with.. also, are you going AEM or stock ecu?? i see your in Miami maybe take a ride up and i can go over all the options with you..
btw.. I like the screen name.. if you want 1000AWHP we can do that too.. LOL
Mike
Old Nov 28, 2008 | 06:29 PM
btownsoccer22's Avatar
hm
Old Nov 28, 2008 | 07:19 PM
1000AWHP's Avatar
LOL, thanks man! Ill have to see where u guys r located, Iv seen ur name many times before...
Old Nov 28, 2008 | 08:21 PM
Originally Posted by btownsoccer22
Hey Mike i need your help on picking the best cams for my application.
PM me with details of your setup..
Mike
