Help with wb02 !!!
Old Dec 1, 2008 | 11:36 PM
fvaldes's Avatar
Help with wb02 !!!
I just installed a LC-1 wb02 and it is working properly. I have been trying to do some logs with Evoscan and it is not recognizing the USB connection. It is working fine though becuse I can change parameters in the LC-1 when I run their driver but when I try to log with evoscan and I punch the Start Logging button I get a yellow message that says USB connection not recognized. I tryied everything from selecting in Evoscan the correct port and choosing LC-1 as the source.
Any ideas?
Old Dec 2, 2008 | 12:31 AM
RABYRAB's Avatar
check your grounds, check for current software, and i would search the evoscan forums.
the terminal plugs on the inovative dont realy fail and go straight to the box soi would put my money on the software side of the problem.
