best clutch for 6-speed?
i'v been doing a lot of searching on clutch information and had decided to get the quartermasters clutch. But recently through some searches, i have found that the quartermaster is not a good clutch for the 6-speed.
what is a good clutch for the 6-speed?
softer than the ACT, but im starting to have getting into gear problems at a dead stop, i adjusted my clutch, etc, ACT is a good way to go, but be careful, its stiff
im pretty sure exedy is best way to go with these evo's anyhow, but i just got the 1 bad one
Just put in an Exedy twin 1000+ miles ago, pedal is a little harder than stock but you forget about it being harder in about 2 days, grab is good, can slip it good, expensive yes, throw out bearing is really loud when pedal is pushed in. had to adjust clutch pedal forever but now its good, I really was thinking quarter master and think that if I was going to do it again I would give it a go just to try something new, but as of now I am very happy and am ready for the big turbo to go on so i can really check this thing out :-) PM me with any questions and I will be happy to help, What mods you have will also change your mind on clutch also what type of driving you do. Only thing I wish about the exedy is that the throw out bearing you be silent, but its not and so what, works really well, seems like it likes you to abuse it allot actually, the harder you hit it the better everything goes into gear and such :-) not that you want to drive hard all the time. Even great for me as a Daily driver.
