Vacuum line routing
Old Dec 9, 2008 | 06:12 AM
MR Turco's Avatar
Vacuum line routing
I figured this might be good info to have on file. For anyone curious of where all the vacuum lines go or how they are routed below is a pic of how it all works:
Old Dec 9, 2008 | 08:31 AM
MasterNater's Avatar
Thanks man. I just recently removed my intake manifold and head. This might come in handy when I finally get around to putting everything back together.
Old Dec 11, 2008 | 08:55 AM
siceclipse's Avatar
nice!
Old Dec 11, 2008 | 11:31 AM
HighwayStarX's Avatar
Nice post! Thanks for that diagram.
Old Dec 15, 2008 | 02:28 AM
huevosrancheros's Avatar
+1 to MR TURCO for being bad @$$ and posting this diagram! Good Job, sir!!!
Old Jul 27, 2009 | 01:47 PM
pshooter's Avatar
I'm having a similar problem with my all stock IX MR.
1-1.1 bar then tapers off. It used to flash to 1.3 -1.4 bar then taper.
I'll be making a leak tester this week.
Interested in knowing if there's a test to check the WG actuator.
Shoe
Old Jul 28, 2009 | 03:39 AM
MR. EVO MR's Avatar
isnt this sticker under the hood on the drivers side?
Old Jul 28, 2009 | 03:43 AM
Fast_Freddie's Avatar
Veteran: Navy
^is for me...
Old Jul 28, 2009 | 11:33 AM
binh's Avatar
Hmm, whats the fuel pressure solenoid?
I have my fule pressure regulator going straight to the intake manifold....
Old Aug 2, 2009 | 06:11 PM
cpages2's Avatar
can someone confirm that the lines related to Turbo, WG, Boost Solanoid and intake are just straight vac lines???
I remember a while back reading there is a pill somewhere in there.
Old Aug 2, 2009 | 09:26 PM
dsevo's Avatar
There are 2 pills between the solenoid and the wastegate.
Old Aug 3, 2009 | 05:57 AM
cpages2's Avatar
Where in line would they be? Also how could I get the pills (auto parts store??). I am going back to stock and dont have orginal vac lines.
Old Apr 29, 2019 | 03:45 AM
Ryan Watson's Avatar
Veteran: Army
Thank you for the diagram! Saved me a bunch of time on looking for my problem!
Old Apr 29, 2019 | 09:47 AM
barneyb's Avatar
Vents the fuel pressure regulator to atmosphere during hot start to clear vapor lock.
Old Apr 29, 2019 | 09:50 AM
barneyb's Avatar
Good question! I think they are hand selected at the factory to standardize boost.
