Magnus Cast + 8000cc = You tell me!!!!
Old Dec 13, 2008 | 06:06 PM
  #31
JohnBradley's Avatar
Originally Posted by steelcityevo8
Yeah it isnt fully into the runner, it actually looks like it is dumping right in front of the runner opening on the plenum.
Its about 10mm down the throat of the runner actually and about 48-50mm off the top of the runner.
What is the exact issue that is suspected will result from the injector placement like this? That is the same rough measurements as the injector boss in a Yamaha 700R and they work well enough out to 127whp and 750cc injectors.
Old Dec 14, 2008 | 09:18 PM
  #32
mandy1's Avatar
yea,but the Yamaha is not boosted.boost will force the fuel to keep in the deep injector boss and will go out in droplets.
Old Dec 14, 2008 | 11:45 PM
  #33
Mine is and the bike I mentioned at 127whp is as well
Old Dec 16, 2008 | 03:41 PM
  #34
Magnus's Avatar
That is completely untrue. If you've seen many other boosted factory cars have this same type of arrangement. The flow testing that we've done with this shows that it actually act like a a venturi, and pulls fuel out of the boss. At that point in injector staging anyway it doesn't matter (read : velocity), because you are always running more fuel pressure than boost pressure, Boost pressure has nothing to do with it, differential pressure does. Anything below the plenum is a low pressure zone.
