Help me cobble together my exhaust...
Old Dec 15, 2008 | 07:45 AM
Bster13's Avatar
Details:
Daily Driver 2006 EVO IX SE looking to keep things as quiet as possible with a 3in straight through exhaust. I plan to track the car a couple of times a year but generally on the street I drive like a sally except for the occasional backroad romp.
Catback:
Cobb
http://www.rallysportdirect.com/shop...c55445ed86fe0b
Downpipe:
Megan
https://www.evolutionm.net/forums/ev...06-evo-ix.html
Resonated Test Pipe:
Megan
https://www.turbowholesale.com/catal...p-p-11214.html
O2 Housing:
Evopowermods 02 dump
http://evopowermods.com/shop/cart/in...index&cPath=65
My question is will these all work together with fittings and whatnot? My car is completely stock right now and I'm just getting started. I will keep the stock turbo, injectors, fuel pump and am considering a FMIC (will have to decide which O2 dump to get....) Are there any other gaskets or hangers I need? thx.
Old Dec 15, 2008 | 08:07 AM
Smike's Avatar
Looks good
I would keep the OE downpipe and cat for inspection time. All should work together and no parts should be needed if all new - they should have gaskets and use the rubber hangers from the factory pieces.
Old Dec 15, 2008 | 09:41 AM
Bster13's Avatar
I was curious about the O2 Dump and track noise regulations...how do they measure these things at a roadtrack? Do they measure you at idle? Full throttle? during the event or in an inspection area?
Old Dec 15, 2008 | 03:39 PM
TouringBubble's Avatar
That looks like a good list of mods.
For dB measurement, they generally measure as you pass a certain location and while you're at WOT. The dump is pretty loud ... some tracks might not like it. It would be best to find out what the restrictions are at your local track to make sure that you would be welcome.
Old Dec 15, 2008 | 03:45 PM
Bster13's Avatar
Where does the dump exit? A fellow board member states:
"You bet they get that technical, its for your own safety. A basic dump is fine for drag racing, your only at WOT for a view seconds. Do that over and over on a road course, how long before you start smelling exhaust gas in the driver’s compartment?"
Old Dec 15, 2008 | 03:54 PM
IHEARTevoIX's Avatar
seriously
search
theres a million stupid threads already made about exhaust
stop clogging to forum with stupid questions
Old Dec 15, 2008 | 04:16 PM
Bster13's Avatar
Thanks Jimmy, you're a peach....and ~extremely~ helpful I might add.
While I do spend a good amount of time reading threads on EVOM, it doesn't pay the bills, so I can't do it as much as I'd like but I did digest this thread and don't recall of any mention of dump exit:
https://www.evolutionm.net/forums/ev...-done-yet.html
As we as looked on http://evopowermods.com/ but no luck. Sorry my searching skills aren't on par with yours.
Old Dec 15, 2008 | 04:41 PM
andy hiralall's Avatar
dude , you should buy my greddy ti with my helix downpipe and midpipe for $700.
the greddy ti come with siclincer and full exhaust only weights 9lbs!!!!
Old Dec 15, 2008 | 04:44 PM
Bster13's Avatar
Thanks for the offer Andy, but I literally just laid down my hard earned cash for the setup (minus the O2 dump) I mentioned above. But thank you again.
Old Dec 15, 2008 | 06:25 PM
BluEVOIX's Avatar
That should be a very quiet system. But I'm on a goal to make it quieter than quiet....
This is what I have installed on my car:
Cobb Down Pipe
TTP resonated testpipe
Jun BL cat-back
Jun BL with V band clamp flanges!
What I'm going to do is cut the super high quality but loud Jun bl muffler off and weld in a Vibrant 3" straight flow through widebody muffler. Here is the picture of the muffler I got.
After that I want to get the Vibrant round version muffler and install that were my resonator or where the catalytic converter was. Hope full this would make it exactly as quiet as stock and as quiet as it can be when WOT.
If this does not come close to my liking, only then I will get the stock like chambered 3" inlet stainless steel muffler from stainless works.
But right now I want to see if its attainable with a non tapering straight flow through 3" system. I'm not a fan of the JDM look, so I'll be putting in a nice 4" stainless steel round ehaust tip. (with rolled tip)
Oh and I had the cobb catback, although it was about quiet enough for me, I want it even quieter than that!
Old Dec 15, 2008 | 07:01 PM
Kracka's Avatar
O2 dump does not equal quiet. Get an internally routed 02 housing.
My recommendation for a very nice, reasonably priced, quiet, full straight 3" exhaust system:
MAP o2 elim downpipe (internal dump option) ~ $380
Megan Resonated testpipe ~ $60
Perrin catback ~ $380
Old Dec 15, 2008 | 07:04 PM
Bster13's Avatar
Doh, Megan downpipe is on the way....S2kracka, is there another option you'd recommend other than the MAP o2 elim DP?
STM Tuned
Dec 15, 2015 08:13 AM
fomoz
Oct 28, 2012 02:29 PM
ETS Michael
EvoX 'For Sale' External Engine / Power
100
Apr 28, 2011 09:06 AM
Andrew@AMS
Jul 2, 2009 06:43 PM
Speed Corps
Jun 29, 2009 12:54 PM
