help gear fluid leaking after clutch install!!!
Alright so I installed a act 6 puck clutch in my car the clutch and everything works perfect and the car was fine for about 2 days then all of a sudden oil was pouring out from between the tcase and the trans.. now ive heard of instanes like this before and people replace the oring but when i read up on things they were slights leaks..
could this be my problem? i dont remember seeing the oring or installing it but why would it work for a few days then all of a sudden leak?
All help appreciated!
its possible that the o ring got damaged when being installed. your supposed to add a little grease/assembly lube of some sort to the rubber o ring. recheck the tc housing bolts for any looseness torque to 57+7 ft-lb. check fluid level.
