Is the aeromotive fuel rail compatible with the AMS FPR?
Old Dec 21, 2008 | 01:15 PM
DimitrisIX's Avatar
I just want to make sure that the aeromotive fuel rail is plug and play with the AMS fuel lab FPR kit. No extra fittings required?
thanks
Old Dec 21, 2008 | 03:22 PM
E7R's Avatar
E7R
Nice choice the Aeromotive rail,have a look at Buschur's new bolt on FPR.
Old Dec 21, 2008 | 06:48 PM
cssaddictm4's Avatar
The fuel lab FPR is 6AN fittings. As far as I know, the Aeromotive rail has 8AN fittings. So you would definitely need some adapters.
Old Dec 21, 2008 | 07:01 PM
Ivan@AMS's Avatar
The AMS FPR kit comes with a fitting to adapt the factory fuel rail to -6 AN male. If the Aeromotive rail is a direct factory replacement rail then you are good to go. If it has female NPT threaded ends, you will need fittings that convert the rail end to -6 AN male.
We have an AMS rail that is a direct replacement for the factory rail that works with the factory feed / return (and AMS FPR kit)
We also sell an AMS rail with 3/8 NPT female ends if you are looking to do something custom. I cant find it on the site though. It is the rail we use with the 1000HP fuel system.
Old Dec 21, 2008 | 09:58 PM
DimitrisIX's Avatar
ok thank you
