Vacuum readings?
Old Dec 23, 2008 | 05:36 PM
EriCS's Avatar
Vacuum readings?
Quick quest? My oem guage on my evo are reading 48hg/cm at idle. Isn't that not normal and if so what could be the problems... Mods are filter, dp, hfc, cbe, and dtm tune if that matters.
Old Dec 23, 2008 | 05:55 PM
EriCS's Avatar
Help
19DB794's Avatar
Mine reads the same. IIRC even my Defi gauge reads at 20 inHg which is roughly 49-50 cmHg which is the unit the oem gauge uses.
Old Dec 23, 2008 | 06:25 PM
EriCS's Avatar
Okay I was getting both readings confused. I thought there was only 1 measurement.
Old Dec 23, 2008 | 08:15 PM
19DB794's Avatar
There is only 1 unit of measurement per gauge but I have 2 boost gauges in my Evo lol and mine is bone stock so I think yours is fine.
Old Dec 23, 2008 | 08:51 PM
Broxma's Avatar
I'm gonna glom onto this and ask a question rather than start a new post since it's on topic, not to HJ or anything.
I just did a compression test yesterday and had 160+ on all 4, but my vacuum at idle when warm is about 15-17 in/hg.
I would think the answer to my question is yes but, could aftermarket cams cause a lower vacuum reading than stock?
I have HKS cams on both sides and the vacuum seems low to me especially considering the compression readings. Even after working on cars for 2 decades now, I would without a doubt say cams are the thing I know the least about.
/brox
Old Dec 23, 2008 | 08:57 PM
sho669's Avatar
/brox
Yes, different cams will cause different vacuum readings at idle depending on how aggressive they are.
