cometic head gasket size question?? PLEASE
Old Dec 25, 2008 | 02:31 PM
DIDYSIS's Avatar
Looking to get a head gasket and I know my block was bored, .20 over should I get the 85 or 86mm bore head gasket??
Cometic Headgasket,
1.29mm Thick 85mm Bore cgC4157-051
Cometic Headgasket,
1.29mm Thick 86mm Bore cgC4156-051
Old Dec 25, 2008 | 03:02 PM
lemmysports2's Avatar
i bored mine .5 over with weisco pistons and oliver at slowboy recommended that i use and 86mm gasket.
i went with cosworth btw
hope that helps
Old Dec 25, 2008 | 03:49 PM
justboosted02's Avatar
dont use cometic
Old Dec 25, 2008 | 04:10 PM
DIDYSIS's Avatar
Why not?
Originally Posted by justboosted02
dont use cometic
Old Dec 25, 2008 | 04:15 PM
wevo1985's Avatar
i believe that the cometic head gaskit is actually weaker that the oem one. a part like that i wouldnt mind spanding alot of money and buying what the best is just to be safe. i believe its only 50 more for a better one anyway.
Old Dec 25, 2008 | 09:16 PM
Originally Posted by DIDYSIS
Why not?
search
use OEM or cosworth
Old Dec 26, 2008 | 01:13 AM
sonicnofadz's Avatar
Yeah do a search...there are a lot of people putting down SERIOUS power on the OEM MLS head gasket.
Old Dec 26, 2008 | 05:48 AM
DIDYSIS i have a brand new oem metal head gasket, its yours for cheap if you want it (if you determine stock 85mm will work for you)
and i mean the cosworth really isnt that much more $, quality peice, and kind of gives you the peice of mind that you wot have to worry about it in the future.
Old Dec 26, 2008 | 06:00 AM
meckert's Avatar
Here, 1mm= roughly, .040. you bored .020.. don't think you need 86mm.
Old Dec 26, 2008 | 06:43 AM
mega-z's Avatar
oem bro!
Old Dec 26, 2008 | 07:56 AM
Chris@nolimitmotors's Avatar
Use a 86mm cosworth gasket.
Old Dec 26, 2008 | 08:18 AM
Ev0ikon's Avatar
Anyone knows a "cheap" source for 86mm cosworth HG? :}
Old Dec 26, 2008 | 08:27 AM
mr.green's Avatar
I have a Cometic headgasket and have zero issues with it. If you are bored over I would think you do a 86mm.
I went with the theory if Cometic was a good choice for older 4g63's why wouldn't it be for newer ones. I had lots of friends use them with no trouble. I really don't believe a headgasket like an HKS or anything will be built 200+ dollars differently then a OEM or more affordable brand.
Old Dec 26, 2008 | 08:37 AM
We have them in stock if you need one.
BlueDemon's Avatar
Call the vendor above you.
